Clock fast/slow Jag XJ8 Vanden Plas
I say nobody seems to answer this question. Original clock was perfect then began to run fast and sometime slow. I bout another one and it acts the same way, so there must be a system issue not the clock.
I have heard a hard reset might cure this (?) Any ideas |
Welcome to this friendly Forum,
Your car's technical section is XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum if you can't find the right time with a query then post your question there. and there's a Regional one too Western US - AK CA NV OR UT HI WA ID - Jaguar Forums - Jaguar Enthusiasts Forum Enjoy your membership here. |
Welcome to the forum mishactoyn,
Of the many things a Hard Reset does affect, I would not expect it to have any influence on accuracy of the analogue clock. Follow Steve's link to the X308 tech section for help, advice and information. The 'HOW TO' thread at the top there is a good place to start for info on regular issues. Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. Enjoy the forum. Graham |
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. |
At one time analog electric car clocks were built with self adjusting regulators.
Repeated adjustments forward would cause the regulator to shift faster and vice versa. On that type of clock, habitually over running the adjustment and then reversing will have the effect of negating the self adjusting regulator mechanism. |
https://www.jaguarforums.com/forum/a...ine=1355077469
Welcome aboard....... good to have you here with us here at Jaguarforums Any useful site information you may need such as how to post pictures, edit signatures, add videos, use the search facility etc, can be found here within the following link Helpful_information Please also take the time to check out the regional section for your area! There are lots of members local to you with the same interests with info on local dealers and possible meets. Regional - Jaguar Forums - Jaguar Enthusiasts Forum I've manually upgraded you to Full forum access so you can better view the site and all its features Please Jump on in and enjoy the site................. :icon_beerchug: |
Originally Posted by plums
(Post 741922)
Repeated adjustments forward would cause the regulator to shift faster and vice versa. On that type of clock, habitually over running the adjustment and then reversing will have the effect of negating the self adjusting regulator mechanism. understood, I have done that too much. I hsve now left it alone for a few days, and it seems to have settled down. I will tell you later if it wored for me. |
Thanks, I kept fiddling with it and finally it did come right.
welcome to the forum!!
| All times are GMT -5. The time now is 10:17 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
