Help wanted pls. Re Bulb warning.
HI. Im new to the forum so if I have posted in the wrong place or stuffed up pls let me now as my last post went missing.
My problem is with my XJ40 Daimler. The Bulb/circuit warning light is on. The right low voltage parker in the head light doesnt work. I have tested the Globe all ok I have no power to the globe. I have tried 4 different globe releys all do the same thing no power to the parker in the head light. Ive had an auto electrician out and hes not sure what to do without a wire diagram. Last question if no one can help where can I get a wire diagram. Thanks in advance Bret. |
Originally Posted by Sandman
(Post 1946169)
HI. Im new to the forum so if I have posted in the wrong place or stuffed up pls let me now as my last post went missing......
Welcome to the forum Bret, Good to have you with us at Jaguar forums. NO - your last post hasn't gone missing and it IS in the right place - the XJ40 forum. Here's the direct link to it: https://www.jaguarforums.com/forum/x...-light-206479/ The 'HOW TO' thread at the top of XJ40 forum is a good place to start for information on regular issues. Please add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the Australia - Victoria/Tasmania Region forum by following this link https://www.jaguarforums.com/forum/australia-victoria-tasmania-94/ to find other members in your region. Enjoy the forums. Graham |
Welcome aboard Bret. |
Welcome to the forums.
Welcome to the Forums.
The XJ40 bulb failure, oh boy, that brings back nightmares, but we sorted it eventually. Good luck. |
Welcome to Jaguar Forums Bret,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
Hello, Bret,
Welcome to the forums from ElinorB. (';') |
