Hey from Colo
1989 xjs #5 10 amp fuse blows when brake is used,
Thanks |
Hello, Rick,
Our XJS section will doubtless be able to help you with your fuse problem. Someone will be along shortly to direct you there. Welcome to the forums from EliorB. (';') |
Welcome aboard Rick.
Welcome to the forum Regular rick,
Good to have you with us at Jaguar forums. Follow this link https://www.jaguarforums.com/forum/xjs-x27-32/ to the XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues. Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the USA Central Region forum by following this link https://www.jaguarforums.com/forum/usa-central-mt-wy-co-nd-sd-ne-ks-36/ to find other members in your region. Enjoy the forums. Graham |
Welcome.
Welcome to Jaguar Forums Regular rick,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
<p>welcome to the forum - enjoy!!!</p>
Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link Using JF "How To" There are lots of members local to you with the same interests with info on local dealers and possible meets. Regional - Jaguar Forums - Jaguar Enthusiasts Forum Need a Manual, a TSB, or General Info' about your Jag? Check out our >> DOWNLOAD AREA << I've manually upgraded you to Full forum access so you can better view the site and all its features. |
