I love my jag but she dont love me
Hey everyone glad to have found this forum,I just bought a 2001 xk8, with bad engine, replaced it with a 2000 xj8 engine the car was a joy to ride til the rain now I,m in failsafe mode
1faraway, sorry to hear that the kitty isn't feeling well. Taking a wild stab in the dark, I would venture to guess that the seal for the plug on the throttle body is leaking, leading to a problem with throttle control. Granted, may be a damaged TPS sensor too. Either are likely suspects with this. Hopefully when you got the failsafe mode alarm, it also threw up the check engine light. That will shed a lot of light on this. So, if your CEL is lit, go to a local auto parts store and have them read the code(s) for you. THen we can get you taken care of with more precise information.
So, sit back, enjoy a cup of Joe and see what you can learn about your kitty. Stop by the XK forum and hopefully someone down there can give you a bit more insight into what is going on as the XK8 is not my specialty. |
Well the codes i got were 1367, 0121,1111, tried to clean connectors and tb, but have'nt taken it completely off looks like four bolts holding it in but unsure if this is beyond my skill set, where does the tps harness end how do i test for a short
1faraway, the other end of the wires for the TPS is at the ECU. What I would tell you to do is to first remove the plug at the TB and using some compressed air (air in a can will work) and blow out the plug really good to make sure it is dry. ALso, do an inspection of the plug to make sure the connectors inside the plug look good. Next, locate the ECU (I don't have my JTIS, so, I am not sure where the ECU is located inside your vehicle) and then check the plug there for the same things (really look at whether the plug is on there tight and also the gasket is in good condition and not ripped). IF all this looks good and the problem continues, odds are you will need a new TPS. All of this should be within your capabilities. REplacing the TPS is nothing more than 2 screws and a plug, then the TPS slides off. No special programming is needed.
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
Oh one other thing you need to put your car details in your signature. I am speaking of the Year, Make & Model. Without it you may not get the input you are looking for. Please take a moment and read the information provided to you explaining the rules. Be patient and enjoy the site. Yes the TB plug will give you a FailSafe mode. This link should help TBoddy |
Well yesterday I removed the throttle body wasnt going to be happy until i did ,cleaned it with crc tb cleaner, spayed and cleaned all connectors with crc electronic cleaner and put it all back cleaned the grounds under the left side fuse box and slowly pressed the pedal up and down for a five count three times, remove the negative battery cable touched it to the positive waited 20 seconds and put it back on let car idle for 10 min then drove a couple of blocks in normal and sport, nothing yet but have not gone far still would like to know how to follow these wires
welcome faraway, if you'd like some more technical help, I'd definitely get your topic started over in the xk8-r area, as you'll get lots of welcomes and greetings from members with different models...less likely to get specific advice. It does sound like you're on the right path, I too think its TB related...especially when water is introduced into the chain of events leading to the problem. Good luck to ya!
Welcome to the forum hope things remain sorted.
1 Attachment(s)
Attachment 172723
welcome aboard Great site here with some top people and above all friendly and helpful, I'm sure you'll enjoy it. I've upgraded you to full forum access so you can better view the sites features. |
Welcome to the forum,
Fingers crossed that you fived it, I'm sure the Jag must be warming to you now! |
Things are good just got off the road put a least 200 miles since the fix so far so good
Good to know that you got it fixed. You can find a oneline for your car along with OBD codes if you need them Jaguar xk I hope this helps!
