Jag series3 / 3.4 Litre
Old Nov 20, 2014 | 10:26 PM
burtontrentjaguar's Avatar
Default Jag series3 / 3.4 Litre
Hi everyone I'm new on this and I live in NZ.
I have bought a Jaguar 3 series with a 3.4 liter motor. Twin SU Carbs not injected.
I'm a European Car machanic but mainly work on Audi VW.
I have a Mercedes 1969 280SE which needs a repaint apart from that its mint.
Also, I have I think (correct me if i'm wrong, I often am?) The only Audi 200 Turbo Qauttro Avant in NZ. There are some 100's, also 200 sedans.
Now I've bought the Jag just to give myself more projects? Am I crazy?
Probably!
I also do country music with and without a band on my first album to be released in NZ.
Anyway can anyone confer; Are the fuel pumps in the tanks on a 3.4 Liter series 3?
My Haynes manual is not very discriptive and does not even show 314 on the wiring diagrams for the fuel relay? situated I think on Bulkhead. There is a Relay with C1/C2/C4/W1/W2 my book shows it should have a C3? The same I suppose? ANyway no fuel to motor, lots of other electrics not available as well. Is this this the "Liven" up relay on the Bulkhead? All Lights work. Just won't start. Burton
Old Nov 20, 2014 | 10:53 PM
Doug's Avatar
Pumps in the tanks on the 3.4 models, yes.
The relay you've mentioned--- C1, C2, etc ---- sounds like the starter relay.
I can't find any wiring info for the 3.4 models, sorry.
Others will chime in.
Welcome to the group, by the way
Old Nov 21, 2014 | 03:55 AM
Welcome to the forum burtontrentjaguar,
Follow this link XJ6 & XJ12 Series I, II & III - Jaguar Forums - Jaguar Enthusiasts Forum to the XJ6 Series I, II & III forum for help, advice and information.
That is the place to post tech questions on your model. The 'HOW TO' thread at the top is a good place to start for info on regular issues.
You can also visit the New Zealand Region forum by following this link https://www.jaguarforums.com/forum/new-zealand-97/
Enjoy the forums.
Old Nov 21, 2014 | 05:04 AM
o1xjr's Avatar
Old Nov 21, 2014 | 05:37 AM
welcome to the forum!
Old Nov 21, 2014 | 06:04 AM
Welcome aboard.
Doug is right, as always.
Think of the 3.4 NZ car as a Series 2 carby car. Almost the same.
Wiring etc will be sooooo close it should not cause that much grief, especially with the knowledge of the other "class" stuff you mess with.
Somewhere, HAHAHAHA, in my shed is a 3.4 book. I will find it as soon as I can and repost whatever I think is relevant.
The S2 had an oil switch (worked in reverse) that controlled the "earth" of the fuel pump relay. Sooooo, no oil pressure = NO pumps, but since the carbies were full of fuel, the engine started, and the oil pressure appeared, the relay switched ON, and the pumps whirred, and the whole thing just did what it did, SIMPLE.
Look down near the oil filter housing, and rearward of it, screwed diect into the engine block oil gallery MAY be one or two oil switches. Some engines have the second up almost under the power steer pump mounting bracket, so LOOK AROUND. Now, one of these is the idiot light, the other is the fuel pump relay switch. There will also be a HUGE looking oil switch, usually screwed direct into the oil filter alloy housing topside, that is for the gauge, DO NOT mess with that, it is big $$. Once you find the correct switch, remove the wire, earth it out, try again.
Fun wil be had.
Crazy???, of course you are, as am I.
Last edited by Grant Francis; Nov 21, 2014 at 06:06 AM. Reason: Spelling still sucks
Old Nov 21, 2014 | 08:47 AM
Welcome to Jaguar Forums burtontrentjaguar,
Old Nov 21, 2014 | 03:27 PM
Smile
Originally Posted by Grant Francis
Welcome aboard.
Fun wil be had.
Yes I probably am crazy two was enough to take care of, imagine what would happen if the Governments said; All old cars off the road! It would never happen? There'd be mayhem! Ha! Thanks again.........Burton
Old Nov 21, 2014 | 03:50 PM
Just like to say Thanks! for all of the comments and what a friendly place to come to, so many of you have good senses of humour. Does that arrive from all of the tedious hours of working on Jaguars, because the wiring is a nightmare.
A man is on the M1 gets pulled over for speeding by an Officer.
He says to the driver; You were doing 120MPH in your Jag sir!
No I was'nt I was doing exactly the speed limit.
The wife reaches over and say's; It no use argueing with him when he's had a drink.
(One of my favourites) Burton
Old Nov 24, 2014 | 06:25 PM
Helpful_information
VinnyT
72
Sep 28, 2025 12:17 PM
bamforp
Aug 14, 2024 05:36 PM
Doovoe
Sep 8, 2015 05:42 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
MrMellor
Sep 7, 2015 10:22 AM
