Jlr ids sdd
my jlr patch files not working........network
The network connection could not be established with TOPIx |
Welcome to the forum Kla Geeks,
The Intro forum is an opportunity for you to tell us something about yoursef and your vehicle and for us to give you some advice on finding the relevant subforums and information. So far I can't tell what you drive, where you are or which version of SDD you are trying to run ..............? Graham |
Welcome aboard.
Welcome, when you get it sorted, all will be fine.
sdd v153...
Originally Posted by Kla Geeks
(Post 1911649)
sdd v153...
I've replied to your identical post in General Tech Help explaining why you can't crack SDD v1.53. Graham |
Welcome to the forums.
Welcome to Jaguar Forums Kla Geeks,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
I was using ids sdd v153 my computer got messed up i made a fresh install ofthe all system....after feeding the cracks it doesn't connect to the internet it says no connection to the topix servers i am stack here
1 Attachment(s)
If you are using a patched (cracked) SDD version, you never want to connect to the internet or it will try to update and simply stop working.
If you want a standard version of SDD to update and use for module configuration, you may as well install current version 153 and connect to TOPIx to download the additional files. Does your TOPIx login work and do you have a current paid subscription to it? Attachment 216501 Depending on your broadband connection, you will need at least an hour of paid time to download the SPF and VDA files. Graham |
patch files were working fine just few weeks the are not working as the used toohttps://cimg3.ibsrv.net/gimg/www.jag...cac98f0a0c.jpg
Hit Continue - with a patched SDD the last thing you want is for it to connect to the internet.
Graham |
