New to Forum - Need Help with 1995 XJS
Hi,
I've been looking through your site trying to find an answer to my problem. I bought a 1995 XJS 6 cylinder. The car ran great for 3 weeks. Now the car will start and run great as long as you don't try to drive it! Sitting still, I can start the car and tach the engine up to 1600 RPM and it is fine. Any higher on the RPM the car will backfire and then there's an incredible smell of gasoline. If I take my foot off the gas it will continue running just fine. Here's what's been done so far: New Cam position sensor Used Potentiometer in the throttle body New MAP air flow sensor New Temperature sensor The issue has not gone away. I was reading your forum about adjusting the Potentiometer, but since I've changed it and the problem still exists, I'm thinking that's not the problem. Fortunately, I have another car to drive. Any ideas on this one? I'm at a loss...... this car is in really great shape, but it won't go. Thanks, Buzz |
Hello, Buzz,
Someone will be along soon to direct you to the correct section where you can find help for this problem. Until then, Welcome to the forums from ElinorB. (';') |
Welcome aboard Buzz.
Welcome to the forum Buzz,
Good to have you with us at Jaguar forums. I've copied your question to XJS forum for advice from members with the same model. Here's the direct link to it: https://www.jaguarforums.com/forum/x...95-xjs-156026/ Follow this link XJS ( X27 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the main XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for info on regular issues. Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the US Mid Atlantic Region forum by following this link US Mid Atlantic - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region. Enjoy the forums. Graham |
Welcome to Jaguar Forums Buzz,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
Welcome.
Thanks everyone for the warm welcome......
These newer Jaguars are foreign to me..... No pun intended...... I'm familiar with the older ones that have carburetors.... these electronics are driving me crazy! |
I'm checking out the new forum now.....
Sorry - I'm not logging in every day. |
Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link Using JF "How To" There are lots of members local to you with the same interests with info on local dealers and possible meets. Regional - Jaguar Forums - Jaguar Enthusiasts Forum Need a Manual, a TSB, or General Info' about your Jag? Check out our >> DOWNLOAD AREA << I've manually upgraded you to Full forum access so you can better view the site and all its features |
