New Xtype in NE Arkansas
Hello everyone, this is my first Jag!! I've wanted one since I was 16 and it only took 14 to get it. Well, I've been on here a lot as a guest, as I've done most of my maintenance since November when I got mine used w/85k miles on the clock. I did oil & filter, fuel filter, cabin air filter, headlight bulbs, poor man's ATF flush and I had a shop do the belts(cuz I was nervous about the tensioner breaking). I want to do the transfer case and diff oil change and the spark plugs and intake manifold gaskets. If you have any tips on these, much would be appreciated!! Well, take it easy and I'll holler at you on the boards.
Welcome to the forums from Batesville.
Happy 30th. birthday. Enjoy the drive. |
Thanks! You know I will!!
Welcome to the forum William,
Good to have you with us at Jaguar forums. It sounds like you've already found your way to the X-Type forum so there's no need for a link to it from me. The 'HOW TO' thread at the top is a good place to start for information on regular issues. Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the US Southern Midwest Region forum by following this link https://www.jaguarforums.com/forum/u...rn-midwest-67/ to find other members in your region. Enjoy the forums. Graham |
Hello, William,
Congratulations on your First Jaguar! Welcome to the forums from ElinorB. (';') |
Welcome to the forums.
Welcome aboard William.
Welcome William I'm in NEA myself. A little place called Tuckerman. Again Welcome.
Jack |
Welcome.
Another SENSIBLE owner, doing all that Catch Up, and then enjoying the Jag, well done. |
Welcome to Jaguar Forums William,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
