Radio won't work fuse is fine. Help!?!
Drove under tree branch doing under 5 mph and antenna hit branch. Then antenna went down. Lost power to radio. Checked all fuses and none are blown. Up for suggestions on what to check now. Help!?!
Welcome to the forum Voss91si,
I think I can safely assume you have a Jaguar but a hint on model and year will go a long way to help us give you some advice........................... Graham |
Good to have you with us. If you haven't already done so you should add your car details to your signature to help others to help you. |
Sorry all. The car is a 2000 Jaguar XJ8 Vanden Plas
Hi Voss91si,
That's a strange combination of events as they are separately fused. The radio/cassette fuse is No 9 in the rear compartment LH heelboard fusebox whereas the aerial is fuse No 9 in the Luggage Compartment fusebox. There's a secondary fuse for the audio system at fuse No 3 in the Luggage Compartment fusebox so you should also check that one. If that doesn't locate the issue, follow this link Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 section for help, advice and information. Remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User ID button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the US Southwest Region section by following this link Southwest US - AZ TX NM OK - Jaguar Forums - Jaguar Enthusiasts Forum to find other members in your region. Is the tree :icon_tree: OK? :icon_lol: Enjoy the forum. Graham |
1 Attachment(s)
Attachment 159401
Hey & welcome aboard, good to have you here with us here at JF Any useful information you may need such as how to post pictures, edit signatures, add videos, use the search facility etc, can be found here Helpful_information Please take the time to check out the regional section for your area? There are lots of members local to you with the same interests. Regional - Jaguar Forums - Jaguar Enthusiasts Forum I've manually upgraded you to full forum access so you can better view the whole site and all its features. Please Jump on in and enjoy the site................. See you in the forums :icon_beerchug: |
