Retrofit Adaptive Cruise Control to X356 with Factory Cruise Control
Hi, I have a Jaguar XJ X356, Model Code XJTDVI, Build Date 01/2007 which I bought new in New Zealand. The car was factory fitted with Cruise Control, but I am looking to upgrade this to Adaptive Cruise Control. We ran a diagnostics test yesterday using Autologic which confirmed the Jaguar Software Version is 3.51.0 and the Main Software Version is 6.7.0. The Autologic gave the option of adding the ACC module, so it would appear that the car was prepped for this at the factory. Please can anyone give any advice, including the additional parts required (front radar, steering wheel switches etc)? I had an initial discussion with BBA Reman last week, but didn't have the Diagnostic information above at the time. Thanks & regards.
Hello,
Someone will be along shortly to direct you to the correct section where you can get help and advice for that cruise control. Welcome to the forums from ElinorB, (';') |
Welcome to the forum SilverXJX356, Good to have you with us at Jaguar forums. All things are possible given sufficient determination and money! Follow this link https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X350 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. Please add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the New Zealand Region forum by following this link https://www.jaguarforums.com/forum/new-zealand-97/ to find other members in your region. Enjoy the forums. Graham |
Welcome aboard. |
Welcome to Jaguar Forums SilverXJX356,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
Welcome to the Forums.
I agree with Brutal. |
Welcome to the forums SilverXJX356. I agree with the comments above.
I have added you to the NZ Roll Call thread. https://www.jaguarforums.com/forum/n...intros-119622/ |
Originally Posted by Brutal
(Post 2013586)
Don't forget the internal spring inside the bellows |
Progress on this build.
Parts plated and painted, new bellow purchased and new plug wired on to the soliniod both ends with high temp wire. I tested the solenoid both work but the Ohms reading on one was 50 ohms where the manual says max 20-30 from memory. https://cimg2.ibsrv.net/gimg/www.jag...57190973b3.jpg Time to test the wiring as per the BOOK...... Here I am hoping for some help please! I will try an explain my writing...done in the bottom of the car. https://cimg9.ibsrv.net/gimg/www.jag...300fd45b88.jpg All grounds tested back to neg - battery. 1) test black wire to ground - yes 2) yellow/purple wire - connects to inhibit switch should read low ohms in P - reads ground) but open / not ground in Drive) - might be meter but close to whats needed. 3) Black/Pink wire - to stalk - reads open and ground when pressed - so all good 4) black/slate wire connected to major switch - should open in on/off and ground on resume - reads - off / ground, on / open, resume / ground 5) yellow / white wire - connected to bellows should read 25/30ohms - reads ground and open when brake pedal pressed like it should.... again could be meter...they read 50ohm and 30ohms at the solenoids. 6) Yellow/black wire is connected to vacuum solenoid should read 50-60oms reads - ground 7) yellow /orange wire 12v - all good 8) green/ purple - connected brake light switch read zero volts and 12v when brake pedal pressed - yep all good. so that is the test- result is ground when there should be ohms...... is it the meter? Power Probe 3 - connected to positive and neutral on the battery, is this meter sensitive enough to read low ohms or more suited to find shorts? Lots of wire to read through from battery? |
This needs to be continued in the Model forum. Many members read Intros, several reply but few return to them once they have done that.
I've taken relevant posts (left out the "welcomes") and started it as a new thread here: https://www.jaguarforums.com/forum/x...ontrol-215221/ Graham |
