Wayne Jones
Recently acquired 2007 Jaguar XJ8 VDP 36000K now has 39000K has hot start problem. Cranks fine in AM after driving shutting off will not turn over makes no attempt. However, instrument panel lights and headlight will come on. After sitting 15 to 20 minutes turns over cranks and runs fine. Battery cranking amps checks out but shows low voltage. Is anyone familiar with this?
Hello, Wayne,
Someone will be along soon to direct you to the correct section where you can get help for your problem. Welcome to the forums from ElinorB. (';') |
Any useful site information you may need such as how to post pictures, edit signatures, add videos, using the search facility etc, can be found here within the following link Using JF "How To" There are lots of members local to you with the same interests with info on local dealers and possible meets. Regional - Jaguar Forums - Jaguar Enthusiasts Forum Need a Manual, a TSB, or General Info' about your Jag? Check out our >> DOWNLOAD AREA << I've manually upgraded you to Full forum access so you can better view the site and all its features. |
Welcome to the forum Wayne,
Good to have you with us at Jaguar forums. Follow this link https://www.jaguarforums.com/forum/xj-xj6-xj8-xjr-x350-x358-28/ to the X350 forum for help, advice and information. Please remember to add vehicle details to your Signature to help others to give relevant advice. Go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details. You can also visit the USA Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/ to find other members in your region. Enjoy the forums. Graham |
<p>welcome to the forum - enjoy!!</p>
Welcome to Jaguar ForumsWayne,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
