When your Jaguar XF window washer stops
my friend has a jag xf like mine. his window washer stopped working. apparently, this is due to the bottom of the water bottle being blocked.
cleaning your jets out wont work, so you have to take the front wheel off and the cowling to take out the water bottle to clean it out. could cost £80.00. sinple solution. drain the water out, put new hot water in then put two false teeth cleaning tablets called steradent, trhis will clean the gum from the botton for a few quid |
Welcome aboard.
Welcome to the Forums.
Welcome to the forums nickyboy?,
Good to have you with us. Do you have the original XF (the X250 from 2007 - 2015) or the current (X260 from 2015 to date)? Please read the guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started. Enjoy the forums. Graham |
Hello, Nick,
Nice trick! Welcome to the forum from ElinorB. (';') |
Welcome to Jaguar Forums nickyboy?,
Good to have you with us. Enjoy the forum. If you haven't done so already you should add your car details to your signature to help others to help you. If you need help with getting around and using the forum follow this link for some help Forum Help |
