2019 AM V8 Vantage vs F-Type SVR
Which one do you prefer and why? Let's start with the Vantage specs:
2019 Aston Martin V8 Vantage Specs
Engine type - Number of cylinders :V 8
Engine Position :Front
Engine size - Displacement - Engine capacity :3982 cm3 or 243 cu-in
Bore x Stroke :83.0 x 92.0 mm
3.27 x 3.62 inches
Number of valves :32 Valves
Aspiration :Bi-Turbo
Compression Ratio :11.3
Maximum power - Output - Horsepower :503 PS or 496 bhp or 370 kW @ 6000 rpm
Maximum torque :685 Nm or 505 lb.ft @ 2000 rpm
Top Speed :314 km/h or 195 Mph
Acceleration 0 to 100 km/h (0 to 62 mph) :3.6 s
Fuel consumption of 11 litres/100km - 26 mpg UK - 21 mpg US (Average),
Drive wheels - Traction - Drivetrain :RWD
Transmission Gearbox - Number of speeds :
8 speed Sequential Automatic
Wheelbase :270.4 cm or 106.46 inches
Length :446.5 cm or 175.79 inches
Width :194.2 cm or 76.46 inches
Height :127.3 cm or 50.12 inches
Num. of Seats :2
Front Brakes - Disc dimensions :Vented Discs (- mm)
Rear Brakes - Dics dimensions :Vented Discs (- mm)
Front Tyres - Rims dimensions :255/40 R20
Rear Tyres - Rims dimensions :295/35 R20
Curb Weight :1530 kg OR 3373 lbs
Weight-Power Output Ratio :3 kg/hp
Trunk / Boot capacity :350 L
Front Suspension :Independent Double Wishbones. Coil Springs. Anti-roll bar.
Rear Suspension :Multilink. Coil Springs. Anti-roll bar.
https://www.ultimatespecs.com/car-sp...e-2019-V8.html
3.27 x 3.62 inches
Num. of Seats :2
2018 F-Type SVR
Engine Alignment :Longitudinal
Engine size - Displacement - Engine capacity :5000 cm3 or 305.1 cu-in
Bore x Stroke :92.5 x 93.0 mm
3.62 x 3.66 inches
Aspiration :Compressor + Intercooler
Compression Ratio :9,5
Maximum power - Output - Horsepower :575 PS or 567 bhp or 423 kW @ 6500 rpm
Maximum torque :700 Nm or 516 lb.ft @ 3500-5000 rpm
Drive wheels - Traction - Drivetrain :AWD
8 speed Auto Top Speed :322 km/h or 200 Mph
Acceleration 0 to 100 km/h (0 to 62 mph) :3.7 s
Fuel consumption of 11.3 litres/100km - 25 mpg UK - 21 mpg US (Average)
Wheelbase :262.2 cm or 103.23 inches
Length :447.5 cm or 176.18 inches
Width :192.3 cm or 75.71 inches
Height :131.1 cm or 51.61 inches
Front Axle :158.5 cm or 62.4 inches
Rear Axle :161.1 cm or 63.43 inches
Front Brakes - Disc dimensions :Vented Discs (380 mm)
Rear Brakes - Disc dimensions :Vented Discs (376 mm)
Front Tyres - Rims dimensions :265/35 R20
Rear Tyres - Rims dimensions :305/30 R20
Front Wheels Width :9,0"
Rear Wheels Width :11,0"
Curb Weight :1705 kg OR 3759 lbs
Trunk / Boot capacity :310 L
Steering :Rack and pinion Electric
Front Suspension :Coil springs.
Rear Suspension :Coil springs
https://www.ultimatespecs.com/car-sp...75HP-Auto.html
3.62 x 3.66 inches
Jaguar Forums Editor
Jaguar Press release
03-25-2019 04:12 PM
JaguarFtypeR
12-21-2018 07:33 PM
