Go Back  Jaguar Forums - Jaguar Enthusiasts Forum > General Jaguar Forums > Off Topic
Reload this Page >
Any idea how to fix streaky/hazy wipers?
Off Topic A place for you car junkies to boldly post off topic. ALMOST anything goes. Fun, laughs and good times here.
Old 03-28-2018, 07:02 PM
Liked 449 Times in 377 Posts
Default Any idea how to fix streaky/hazy wipers?
This is not my video, but I am having a similar issue with my daily drivers that are machine washed:
I have a brand new Honda and the first time I washed it at the machine wash, I immediately noticed that the wipers were very streaky. I suspect it has something to do with the car wash soap/wax leaving a residue. I have another daily driver that is not new and has similar issues, but gets washed at the same place. I tried using RainX washer fluid after the issue became apparent, and it did not help.
Any ideas what is going on here and how I can fix it? I tried using "Invisible Glass" on the exterior of the windshield and it made no difference.
Believe me, my XKR never sees a machine wash and I don't have time to hand wash my daily drivers.
Old 03-28-2018, 08:03 PM
Thermo's Avatar
Liked 2,803 Times in 2,376 Posts
amcdonal86, I would first try something like isopropyl alcohol and see if that will strip off the build up. Next, you can go a little stronger with some acetone. Just make sure to apply to a rag and then apply to the window. You don't want these touching the paint on the car.
The final thing I can think of is getting your hands on some 3M Perfect-It III (Stage 2) and some 0000 steel wool. I know what you are thinking, "No F'n way I am rubbing steel wool on my windshield". I was skeptical too. But, after trying it out on some scrap glass, it does work. You put on some of the Perfect-It liquid on the windshield and then using the steel wool, work it into the glass. You will find that this will also remove some of the fine scratches that are in the windshield too. It takes a little bit of elbow grease, but it will pull anything off of the windshield.
The following 2 users liked this post by Thermo:
LnrB (03-29-2018), XJ8JR (03-28-2018)
Old 03-28-2018, 09:50 PM
Thanks, I might try the IPA. I did find this other video recommending a product called No Touch Glass Stripper. It is pretty annoying that I'd pretty much have to apply this after each car wash to avoid the issue!
Old 03-29-2018, 01:24 AM
Steve M's Avatar
Liked 1,194 Times in 907 Posts
Don't forget to clean the wiper blades too; I use vinegar on mine.
Old 03-29-2018, 06:23 AM
Thermo's Avatar
amcdonal86, if you want to try to Perfect It bit, I have some. Come on down and we will give it a try. Besides, the Perfect It works great on everything else on the car (paint, chrome, rims, headlights, etc). I love the product, just a little pricy.
The following users liked this post: Thermo
amcdonal86 (03-29-2018)
Old 03-29-2018, 06:31 AM
Busa's Avatar
Liked 370 Times in 301 Posts
Replace the wiper blades first of all, but don't fit them until after cleaning the windscreen.
Clean the whole windscreen area twice using Autoglym Fast glass by spraying onto the glass in smaller areas and then wipe the glass with clean paper kitchen towel. Don't try and do the whole windscreen in one go.
Work all round the screen in this way and keep using lots of clean paper toweling. I use one whole roll of kitchen towel on cleaning all of the car's windows. This is how I clean my car windows and its quick. The Fast Glass and a roll of paper kitchen towel stay in the car boot/trunk, so if I am out and the screen gets very dirty I can pull over and clean it.
The following users liked this post: Busa
yarpos (03-30-2018)
Old 03-29-2018, 06:53 AM
Liked 2,031 Times in 1,555 Posts
I have been cleaning our various windshields periodically with alcohol, old cotton diapers, and a healthy portion of elbow grease ever since the late 1970s. I also carefully clean the wiper blade inserts with alcohol occasionally and replace them yearly just before the vehicle is due for its annual safety inspection. Works for me....
Old 03-29-2018, 07:00 AM
Busa's Avatar
Good to know people have their own tried and tested and well used methods.
Likewise I change my wiper blades every spring without fail.
Old 03-29-2018, 07:42 AM
Yeah, I think my point is, the car is 1 month old and has 1500 miles on it. Although there may be some sort of wax buildup, the problem is not that the wiper blades are worn out.
Actually now that I think about it, the first time this occured may have been when I applied Collinite 845 when after I hand washed the car the first time (subsequent washes have been at the machine wash). After I removed as much wax as I could, I quickly hand washed the car again, which may have spread wax onto the windshield.
Hopefully that is the case because I will probably continue washing the car at the machine wash (there is only one chain in my county).
JimC64
07-04-2017 07:38 PM
jjd
12-08-2014 03:52 PM
pabanker
07-04-2013 07:28 PM
espy1949
12-06-2011 06:01 PM
iownme
06-30-2011 02:40 AM
Quick Reply: Any idea how to fix streaky/hazy wipers?
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
