Other Jaguar Models / Concepts / Replicas Do you have a Jaguar model not listed above? This is the place to talk about it!
XJ13 - V12 Firing Order
Old 04-24-2019, 11:30 PM
Crackerbuzz's Avatar
Default XJ13 - V12 Firing Order
Hi all,
Thought I would see here who may have some historical information.
Below is a video interview at Goodwood, speaking with the Jaguar representative/driver Richard Mason who drives the XJ13 around the track.
Richard clearly stated in this 2016 interview that the original 4.8L quad cam V12 had a special firing order that gave the XJ13 it's unique sound.
I would love to find out what this firing order is and maybe try and replicate it one day on a 5.3 unit.
Does anyone have information on this?
Watch the video... @ 4:16 when Richard says this quite nonchalantly!
Craig
Old 10-20-2023, 12:05 PM
Neville's Avatar
Hi - first of all, the original quad-cam was 5.0 litres and not 4.8.
Also, Richard is wrong to say the firing order gave the "quad-cam" its distinctive sound (if thats what he said). It uses exactly the same firing order as all Jaguar V12s (1a-6b-5a-2b-3a-4b-6a-1b-2a-5b-4a-3b). This is pretty standard for all V12s.
The first of the XJ13 prototype engines to run (now in my ownership) was tested on the Jaguar testbed by the late Ron Beaty (who later formed Forward Engineering). He did run it in two different ways. The first way is exactly the same as the later V12 but he tried out a different firing order in period. I also tried it and found that it didn't run as nicely, sounded "lumpy" but did run.
There is a 15 degree difference between the banks. It is possible to first fire 1a on one bank then fire 1b after the crank has rotated by 15 degrees. Both these pistons operate on the same crank journal. Then you fire 5a followed (15 degrees later) by 5b. Next is 3a followed by 3b. Then 6a/6b, 2a/2b and 4a/4b.
In this way the firing order runs up and down each crank with each pair of pistons on each journal firing in rapid succession.
knares
08-14-2018 08:48 AM
JigJag
03-22-2017 08:38 AM
surv1984
11-16-2016 08:58 AM
calvindoesntknow
03-21-2015 07:56 PM
Per
11-07-2011 04:54 PM
Quick Reply: XJ13 - V12 Firing Order
