03 s Type 4.2 coolant inlet pipe leaking
I had to replace my thermostat housing assembly on my s Type 4.2 na, after completed I can’t get the coolant inlet pipe to seal. It keeps leaking from where the o-ring is. I’ve pulled it apart and tried different new housing assemblies and still leaks. |
Originally Posted by kaotikd
(Post 2040975)
I had to replace my thermostat housing assembly on my s Type 4.2 na, after completed I can’t get the coolant inlet pipe to seal. It keeps leaking from where the o-ring is. I’ve pulled it apart and tried different new housing assemblies and still leaks. Did you lube the o ring with coolant before install? Did you torque unit down to factory spec? |
Yes I did use a new o-ring with lubrication on it and torqued to correct spec. I even changed the inlet tube under the intake elbow just in case the one had a problem but still leaks. |
