03 S type R no crank/ no fuel pump power/ no start
Old Apr 17, 2026 | 08:50 PM
mmhyson's Avatar
Default 03 S type R no crank/ no fuel pump power/ no start
Hi guys New Jaguar s type r owner
I have an 03 that i am restoring . I drove it in my garage on my lift then I went to start it to move it forward and it wont start now
I have a service manual... all fuses, relays and diodes are working. the anti theft light is showing code 15. I tried to use a smart pro programmer to reset the key but it wouldnt let me. i have communication with my cheapy scan tool to the ecu.
I have done so many tests and i can not figure out why the car wont start and the fuel umps wont turn on.
I am really hoping someone has had a similar experience and this is just something stupid i am over looking.
Any help or suggestions are much appreciated
car currently has 145000 miles and turned on an drove then it didnt.
Old Apr 17, 2026 | 09:09 PM
Peter_of_Australia's Avatar
The internet confirmed to me, what I was thinking anyway:
Code 15 on a Jaguar S-Type indicates a PATS (Passive Anti-Theft System) fault related to the ignition key code, often triggered when the key transponder is not recognized or the ignition cylinder has been replaced with a used part containing unprogrammed keys. This fault code (B1601) means the Engine Control Module (ECM) is disabled, preventing the vehicle from starting.
This means that either the transponder pill (located in the front half of your flip key is somehow defective or the transponder-receiver ring around your ignition lock in the car (which could also be due to faulty wiring to that receiver).
The obvious first question is: How many keys do you have for that car and did you try them all already?
If your issue is that transponder, you need either expensive equipment / hard to get software to "connect" that transponder to you security module again, or you find a specialized locksmith, who can do it.
Having said all this:
If you do have a battery, which is NOT top notch (12.7V at least), all above might not apply and your real problem may be a faulty battery....
Old Apr 18, 2026 | 08:06 AM
mmhyson's Avatar
Thanks for your reply Peter.
I have 2 keys and both worked . it just randomly stopped working.. the battery was at 12.9v. is there a way to test the receiver ring? I have tried using smart pro key programmer and it shows it can do this car but it will not connect to the ecu. I am not one to just throw parts at things and hope it fixes it. But this is frustrating me to no end.
Old Apr 20, 2026 | 07:38 AM
JagV8's Avatar
Hopefully in the workshop manual, free from JagRepair.com - Jaguar Repair Information Resource
drewg
General Tech Help
Jul 3, 2023 07:07 AM
Jmains123
XJ XJ12 ( X305 )
May 6, 2023 01:41 PM
93xjs6cyl
Nov 30, 2022 03:45 PM
mrjimbo
Diesel variants - All models
Mar 1, 2015 08:22 AM
HC~
Jan 3, 2013 06:52 PM
