2001 S-type 3.0
2001 S-type 3.0
good evening and Happy Nee Year
I need some help figuring this out ...
its been a few days I’ve been driving with the electric fan coming on and then I realized the car was low on coolant ... added some WaterWetter , just to realize it’s leaking from the water pump . Changed the water pump yesterday and didn’t know about bleeding the coolant ... today I installed a new thermostat and poured the coolant into the upper hose ... Gets hot ...
What did I miss ?
What did I miss ?
Received 2,183 Likes
you have a air lock more than likely. the small hose that goes to the top of the reservoir is the bleed hose. remove it and fill till coolant bubble out. I also like to then start the car with heater on high to purge a little more air. close it up and run at 2000rpm and you should be good unless you have another issue
FS[UnitedKingdom]: 2001 XK8 Black metallic convertible Jaguar XK8 4.0 auto 2001
Scotchgitt
05-24-2017 01:22 PM
Lionel Turner
04-08-2017 11:53 AM
FS[UnitedKingdom]: 2001 JAGUAR XKR Convertible - Black / Black / Ivory (2001)
Piersman
11-09-2016 01:40 PM
toronadomike
12-11-2013 01:57 AM
texmanmoore
06-30-2008 02:27 PM
