2001 S type p0307 and long crank
Old Mar 19, 2010 | 03:05 PM
gearjam's Avatar
Default 2001 S type p0307 and long crank
Have a #7 cylinder misfire code after new coil and plug replacement. Car was driven about 2000 miles after these parts were put on before the light came on again for cylinder 7. Looking at freeze frame info it says it only happened 1 time at 1800 rpm and set the light. Also sometimes it seems to crank about 10 seconds before starting cold but not always. Put a fuel pressure gauage on it and the fuel pressure bleeds away to 0 after about 20 minites but comes right up when starting. Could the injectors be leaking down when not running. It does seem to smoke some when starting cold like raw fuel??????
Old Aug 4, 2011 | 01:35 AM
JagV8's Avatar
You have P0307 and have replaced both coil and plug on #7?
Have you used the correct meaning of #7? On 2001 car, 1-4 in one bank, 5-8 in the other. See the FAQs for picture etc.
Did you clean plug well & what was in it? Did you reseal with dielectric grease?
stanjag
Dec 29, 2024 08:26 PM
Drew2006
Nov 24, 2015 11:14 AM
celticpiping
Sep 18, 2015 06:17 PM
CaneCounsel007
Sep 3, 2015 07:33 PM
dpappyp
Aug 27, 2015 06:31 AM
