2004 Jaguar STR HELP
Sorry VERY late update
so far I fixed the oil leak through a lot of time and mistakes, the old oil pan bolts are trash and break easy. Two broke off while still in and I had to buy a kit a find out how to take them out myself, yet got it done and did replace all oil pan bolts with some more heavier duty bolts size. m6x1.0 if that comes in handy which it might if changing oil pan gasket. Regardless successfully repaired the oil leak. Replaced all rotors all around and brake pads, also tires. I got all the sensors I needed fixed but currently I do need an lower ac relay clutch. Scanner read "Ac clutch relay control circuit low" but I did forget the code i'll have an update for that soon. Also about an hour from decatur my friend.
Norri (02-18-2019)
Received 6,250 Likes
FS[NorthEast]: 2004 Jaguar STR, $46K miles, GREAT condition!
goblue90
35
07-05-2014 08:33 PM
amgeater
03-06-2013 08:59 AM
goblue90
Sights N Sounds
07-16-2012 09:35 PM
