2005 cabin/pollen filter replacement w/pics FAQ
Old 12-07-2010, 02:30 AM
Received 3,435 Likes on 3,043 Posts
Statement of the obvious: get the replacement before starting a strip-down
The following 2 users liked this post by JagV8:
devo357 (03-06-2014), Jumpin' Jag Flash (10-27-2013)
Old 12-07-2010, 07:35 AM
joycesjag's Avatar
Received 1,436 Likes on 1,077 Posts
Originally Posted by Pushing_Tin View Post
I had no idea what I was doing so it took about 20 minutes before I got the hang of it.
So then my 15 minute timeline was only 5 minutes off. Hey great!!!
Old 12-07-2010, 07:57 AM
The Chris X's Avatar
Just a word of caution for the ham fisted/careless amongst us (me) - I have yet to do this job on the STR, but when I did it on my X type the first time, I sliced my freaking hand on the cowl cover when prying it off. That plastic can be pretty sharp, it was like a large paper cut. Not sure if the S Type is the same or not but just something to keep in mind if so.
But this might be just me, I'm known for finding new and interesting ways of inflicting self-injury.
Old 12-07-2010, 08:07 AM
nixx's Avatar
Good suggestions. Also- if your jag has been in the sun/heat for several years, the cowl cover may have become a little brittle. Use caution when lifting up the corner to access the cabin air filter. A local shop here, Autoscope, broke my cowl cover when they carlessly lifted it up really high. Also, make certain you install the cabin air filter the correct direction. There is an 'AIR FLOW' indicator on it. Autoscope also couldn't quite get that right.
Old 12-07-2010, 11:28 AM
Pushing_Tin's Avatar
Well I thought that since it only took a few minutes I'd take a look and button it back up. Now that it's all apart I'll just drive my truck until I get the filter!
It took me at least 10 minutes to figure out the push/pull pin things! I had no idea how they came off! Thanks for the write-up!
Old 12-07-2010, 12:36 PM
Napa ordered a filter from another store and it will be here in the morning, it was only $20.
Old 12-08-2010, 09:35 AM
Default why o why
I ordered mine from NAPA yesterday here in Canada same part was $58 !!!!! That really p!sses me off
  #28
Old 12-09-2010, 12:46 PM
yfx4's Avatar
OReilly had mine (to order) for $27
This procedure works the same for our 2007 S.
THANK YOU for posting it up!!
Old 03-26-2011, 10:32 AM
Default Jag S Type 05
Just wondering if anyone knows where the cut of in the vin for the change in air filters for an '05. Want to change mine but not sure how? Car is in a Garage till the snow is gone otherwise I'd check myself. Plus I need ten posts to see the pics posted above.
Can anyone throw me a bone?
  #30
Old 03-26-2011, 10:33 AM
Next time check Ebay. Good deals. Got one delivered for less than $20
  #31
Old 03-26-2011, 11:19 AM
vance580's Avatar
Since you dont have 10 posts yet to see pics. Check out my youtube channel in my sig and there is a video of how to on an 05 STR. Should be exactly like yours. That should help you till you get up to 10 posts.
  #33
Old 01-13-2012, 10:41 PM
Just trying to get my ten posts so I can see the pics as well...
  #34
Old 01-14-2012, 05:14 AM
Maybe a mod will upgrade you
  #35
Old 01-14-2012, 06:24 AM
Received 4,758 Likes on 4,274 Posts
I'd go to the off topic section and you'll be done in 5 minutes.
  #36
Old 01-14-2012, 10:57 AM
I have found two types of cabin filters. The better one has the addition of activated charcoal to help with the odors. These are good bit more expensive and harder to find.
I recommend removing the cowl cover completely. As was posted earlier shop's try to rush the job by only partially removing the cowl cover and then prying it up to slip the old filter out and slide the new filter in. Bad idea! I find lots of junk in and around the filter area. So when I change them I use my shop vac to clean out the entire cowl area.
If anyone needs new push pins they are available at any Ford dealership as the Lincoln LS uses them too. Sorry I don't have a part number. You can find a 1/4" push-in nylon rivet at Lowes that works too. Part #H-881207. Just remember to push in the center button to remove. Don't pry them out something will break!
  #37
Old 01-16-2012, 04:08 PM
Changed it yesterday, WOW what a difference!
  #38
Old 04-18-2012, 08:57 PM
2000JagLvr's Avatar
Default My goodness what a mess!
I pulled mine out tonight. I think it was put in around the dawn of time. I found them available, at least in my area, at WallyMart for $18.94.
"cf9846a" - Walmart.com
I only had to undo a few clips and 2 screws to get mine out. However, I dropped a screw and it fell down behind the passenger side headlight. I ended up having to take the bumper halfway off and remove the headlight toget the screw back. I need to get a magnetic tray to hold stray screws.
  #39
Old 09-01-2012, 09:42 AM
Just changed the air filter in my 2005 S Type. Pushed down on center of plastic hold pins, pulled them out, lifted up on cowl, removed and replaced filter. No torx screws. It was fairly clean and had ben replaced with a Micron filter labeled with the Ford logo. My replacement filter was identical except the Ford logo was blacked out.
  #40
Old 09-12-2012, 08:56 AM
carelm's Avatar
I got my latest one from Olympus Auto Parts for $18.50. It was one of the activated charcoal ones. I need to start writing down when I replace filters because the one I removed was pretty nasty. I did the job in the parking lot in about 5 minutes. It was on my lunch hour at work, so no beer.
Quick Reply: 2005 cabin/pollen filter replacement w/pics FAQ
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
