2006 s type sport 3.0 with nav 124000km high pitched noise in reverse
1 Attachment(s)
Good evening everyone! I hope you all are having a rockin weekend.
I got in my car this evening - put it into reverse....heard a high pitched noise coming through the speakers and the P thing on the roof of the car...lit up red....when I put it into drive....the red light went away....Im reverse...came back. Got home....tapped on all the sensors...no water in trunk...strange... Any help would be awesome! I am under warranty till Feb 2013. SIXXDOGG |
sorry i cant help, but what is "the P thing on the roof of the car...lit up red"
thanks |
Ditto to police666..."P" thing, etc.? Clear and more info Sixx Dogg.
Good afternoon!
Ok...on the light dome - there is a P black button...if I push it...it shuts off the front and reverse sensors...it will light up red upon pushing the black P button. Last night - I put my car in reverse....there was a high pitched audible sound and the red light came on.... when I put it on park - the noise went away...and the light went off....in reverse...red light comes back on.... hope this helps! |
ok, is the high pitched noise coming from the parking sensors ? or the gearbox ?
my bad - I was not explaining this correctly...
I did some searching...its the rear bumper sensors... This morning - everything is working fine....I located the box in the trunk on the left of the spare...no water...which is good... Not sure what happened...but it was raining last night as I was driving... Have a great day!! |
1 Attachment(s)
You need a process of elimination.
If in doubt about the source of the noise, temporarily disconnect the harness connections to the Parking Aid Module (item 1) in the luggage compartment: https://www.jaguarforums.com/forum/a...arking-aid-jpg If the high pitched noise stops, it's the sensor system. If not, it's transmission related. Graham |
Everything is working fine now - but when it happened last night - the P on the light dome went RED in reverse...and made a noise for about 4 seconds....then stopped...back up sensors were not working.
Now today...everything is perfect....PHEW! Thank you for the diagram! |
it might be worth checking the boot/trunk for water ingress
