2007 STR Front Brake Pad Removal and Replacement
Anyone had experience replacing front brake pads on a 2007 STR? What is the size hex needed for removing the caliper bolts? Are they like the rear ones that are accessed by removing the plastic plug? I relaced the rear ones today with advice obtained from this forum. Thanks!!!
You need a 9mm hex head. Yes, just pull off the plastic caps for access.
You need to remove the spring clip in the front first. I have been using Jaguar pads for replacements even though they are hard on the rotors. This time I used CENTRIC pads from RockAuto. I'm not too happy with the pedal feel so I will probably go back to Jaguar on the next replacement. It's not a bad job. Good luck. |
Thanks for the reply Ron, but mine seem to have a larger bolt. The largest hex I have is 10mm and it is too small. I have heard that the calipers on the R models are larger than the ones on the standard V8 or V6.
I have a 07 STR as well. Are you sure the socket is going in? The 9mm hex socket goes deep into the back of the caliper to reach the hex bolt.
Ron |
There are black plastic. Caps behind the caliper, you are I suggest looking at the bolts that hold the calipers together.
The R symbol is the spring clip I use EBC red stuff pads far better pads and far less dust. https://www.jaguarforums.com/forum/s...acement-75847/ |
The ref to larger calipers tends to be to Brembos that aren't fitted to the 2007.
