2008 S Type 3.0L changing from 300mm discs to 326mm
Old Dec 27, 2023 | 10:48 AM
JimHatesCalipers's Avatar
Default 2008 S Type 3.0L changing from 300mm discs to 326mm
Having some problems fixing my rear brakes. I could not find the 300mm discs for less than a new mortgage and given that I needed new calipers too (handbrake seized) I decided to make the switch to 326mm discs. Now I am unsure if the mounting brackets for the installed 326mm disc will work on the 'designed for 300mm' set up. I thought I bought the caliper and bracket for 326mm but it does not seem to fit. Wondering if the bolt position for connecting the bracket onto the main assembly is in a different spot for the 300mm and 326mm brake systems? Or are the brackets offset more from bolt to disc surround?
Any help appreciated. This might be more confusing than anything.
Old Dec 27, 2023 | 10:55 AM
xalty's Avatar
knuckles are all have same spacing on everything except brembo cars.
Old Dec 30, 2023 | 01:06 PM
bydand's Avatar
see
https://parts.jaguarlandroverclassic.../brand/jaguar/
I would look for a XF 250 desiel which is being broken and get the 326mm bits from that.
There does seem to be a difference in the part numbers between 300, and 326mm
Seasons Greetings? Or Bah Bumbug!! Which ever??
paddyx350
Feb 10, 2022 07:32 AM
Dan Wink
Aug 2, 2021 06:40 PM
X-TypeMentality
Sep 21, 2016 05:50 PM
sedatev8
General Tech Help
May 10, 2015 12:13 PM
Jag Breeder
Jan 30, 2012 06:05 PM
