AC Compressor shutter
Anyone ever heard this noise? I have isolated it to the ac compressor, it only does this when the ac is off or when the car has just started while the ac is kicking in.
You might check the pulley support bearing. It does not do as much when the clutch is engaged as the shaft bearings do most of the work.
Just a thought. Try removing the belt and grabbing the pulley to check for 'play' in the bearing? Also check the idler and tensioner pulleys just because. bob |
Its the clutch. You need to get that fixed asap or else it'll come off and the belt will no longer turn. Keep RPMs low and no hard accelerations until you get it fixed. (I was a FEAD engineer for 6 yrs)
I've not worked on a jag compressor but chances are good you can just replace the clutch itself and not have to remove the compressor. |
Repair AC Compressor on STR? I would love that.
I will take a look at the clutch and pulleys.
I would LOVE it if I could just fix the actual problem instead of replacing whole parts. It seems to make so much more sense to me. But, pretty much every repair on this car seems to require replacement of a whole part :/ Replacing the AC Compressor on the 4.2l SC engine requires lifting the whole engine off mounts so the bolts will clear a support bar. Pain in the ass. I have not rolled under there to see what clearance I have to work on just the clutch/pulley, but I am super tempted to just try replacing THAT over the whole pump. I have replaced the stupid pump twice so far, and now this. (first replacement was bad from the factory, clutch didn’t work correctly. Second replacement is currently the one we are talking about) Anyone with experience doing this, your advice would be appreciated. |
Climate control unit
Another idea that has been floated, was the Climate control module circuit through the compressor. Could a problem with the climate control module, a wiring issue between the module and the compressor coil cause incomplete clutch engagement?
The idea was that module, wiring or ground could result in less than 12v being sent through the coil, resulting in weak clutch engagement, thus causing excessive wear on the clutch. Anyone ever heard of this? |
Originally Posted by Reklaw1973
(Post 2099147)
I experienced a slipping clutch on my '02 due to arcing at the compressor clutch control relay. Pics of the burnt relay are in post #4 here: https://www.jaguarforums.com/forum/s...2/#post1714573 However, when that happened, the AC performance dropped way off. The coldest temperature I could get from the dash vents was about 50F, not 38F like it should be. The problem was very obvious. Who knows, maybe your car was only putting out 50F air, but that seemed normal to you, I don't know. This is why I keep an inexpensive thermometer in the dash vent at all times. It helps me keep an eye on the AC performance, so I can catch a minor problem before it becomes worse. For giggles, you can remove that relay and pop off the cover. Look for evidence of arcing inside the cover. For your noise issue, try loosening the serpentine belt. With the engine off, have a helper hold a breaker bar on the tensioner. With the tension released, crawl underneath and try to wiggle the main body of the compressor pulley, the part where the belt rides. I suspect you will find some play there. I find it curious that you only get the noise when the AC is off. That sure seems to point to a problem with the clutch assembly wobbling around. I don't think that excessive wear on the clutch face (from low clamping force, for example) would cause this noise. When de-energized, you'd have extra clearance, not less. And in the case of extreme wear, you'd have reduced AC performance (due to slippage when energized), but is that the case? |
Update
So I ordered a new clutch, pulley (with bearing of course) and coil. Raised the car, took the serpentine belt off the compressor and could not feel any play. Everything seemed normal.
While checking everything out under there, I found the top two water pump bolts were not in place 😳 One bolt was still in the track, being unable to fall out because of a support stopping it. The other was gone. With an inability to feel any play or excessive spin on the compressor (or any pulley actually), I thought for sure this bolt was making the shutter I was hearing. So with great dexterity, scraped knuckles, universal joint, a fourteen year old helper and a few extensions we got the remaining bolt back into place. We put the serpentine belt back on, reassembled and started the car. Ran perfectly for about 30 seconds, then the same shutter came back. I crawled back under the running car and observed the compressor pulley rocking in and out visibly when the noise occurred. It seemed pretty obvious it was something wrong with the compressor assembly. So we shut it off, dug back into the job and ultimately gave up. I just cannot get enough leverage in such a tight space. I couldn’t get the clutch unbolted. Such a tough spot on the supercharged STR. Removal of the compressor requires lifting that side of the engine, and I just don’t have the workshop or the knowhow to do that. So it’s not like I can just pull it off the engine and rebuild it on the bench. I will need to cough up the money to get a new compressor installed, and that means a trip to the dealership. Why not have it replaced and under warranty at this point. |
Also
I did swap the relays and it made no change.
(Post 2111326)
Epic Win for the Resolution!
Success!!! A Win!!!
In-Vehicle Replacement of air conditioner compressor pulley:
Special thanks to: Motorcarman: I could not feel the play by hand but I could see it happening if I laid under the car while it was lifted and running. Also, when zoomed in with the inspection camera the play on the pulley bearing was pronounced. Mega Super Special Thanks with a Gold Star to: KR98664 whose massively detailed write up of everything about diagnosing AC systems on a STR was SUPER helpful through this whole adventure. Because of his info I understand a WHOLE lot more about the AC system and I know everything is well with my ears and a simple thermometer I bought for $3. Note:
Another note: In an earlier post I mentioned finding loose “water pump” bolts. I was mistaken, as I meant to say power steering pump bolts. Thank you for not calling me out on the mistake :) Lastly, I consider this post resolved with the install of a new AC pulley. So if you hear the sound in the video at the beginning of this thread, and it becomes a rattle/shutter that comes and goes... it may be the pulley. And if your adventurous, with the right advice, the right tools and a little perseverance, you can fix it! Link to inspection camera: https://www.harborfreight.com/digita...era-61839.html https://cimg2.ibsrv.net/gimg/www.jag...7cf815473.jpeg The light on my inspection camera did well to illuminate the area I was working. https://cimg1.ibsrv.net/gimg/www.jag...cdb73e3e0.jpeg My view of the AC compressor axle and snap ring with the inspection camera. https://cimg0.ibsrv.net/gimg/www.jag...79039d8b4.jpeg Convenient location for the serpentine belt removal tool while I was working. |
(Post 2134172)
Creative use of several zip ties and an S hook worked well to hold the coolant hoses out of the way so I could get my arm into the rather small space to reach the AC clutch/pulley area.
Congratulations on your repair. Excellent use of the inspection camera, by the way. |
Motorcycle Tie down strap
I’m sure a motorcycle tie down strap would have worked. However I didn’t have one, and I did have zip ties. Either way as long as it held the hoses up and out of the way without removing them and subsequently having to refill and bleed the complex cooling system... it would have done the job 👍🏻
2 Attachment(s)
Jaguar did issue a TSB (the ones that nobody reads) for replacing the clutch on the S-Type.
bob |
(Post 2134437)
The big difference here is the pics show how to do it without removing the compressor or even discharging the system. The first step in the TSB is to remove the compressor. Which method is more difficult? Not much clearance to remove the entire compressor, is there? |
