Line in aux in for stype 2003 with gps
you sure can .
Ben from the UK forum shows you how in this vid -
you can also add the cable to the CD Changer in the boot/trunk . there is a how to some were on here ,
or try to purchase an ACM which is the very expensive factory option . if you can find one .
then there is the less than ideal FM modulated type also .
It also has an Ipod cable which I tested way back in 2010? and it's kind of funky to operate as well. I used a Sandisk MP3 player.
Anyway, there are plenty of threads about all of this search or Google it. It's dead end technology now that everyone is utilizing bluetooth.
As i understand it, installing this small machine could be an option PXDXJAG Auxiliary Input Adapter for Select 2000-02 Jaguar S-Type :: Auxiliary Input Adapters
It is however not clear to me if this also works works for the type-s cars after 2002.
I also found this project which sounds quite promising, but I don't know the status of it.
https://www.jaguarforums.com/forum/a...2008-a-184931/
i also have installed one of these . far better sound than a parrot . but not quite as crisp as the veffbox.
it is FM modulated with hands free, and may be the best FM modulated kit i have come across .
its affordable , easy to install .
has bluetooth in .
3.5mm RCA in. male or female.
and RCA in
comes with a flush mount usb charge port . i mounted in the arm rest center console .
mic and cable . it has a switch to internally disconnect the antenna when powered on . to reduce channel interference .
and 3 frequency choices .
https://www.ebay.com/p/Axxess-Mobility-Axm-dc-hf-Hands-Calling-Bluetooth-FM-Modulator-RDS/1330673270
on/ off bypass switch in glovebox
pre programmed banner
hands free mic mounted to roof console
has bluetooth in .
and RCA in
vdpnyc
06-25-2015 08:52 AM
TallXJDriver
10-15-2013 05:20 PM
Skid Mark
08-25-2011 08:50 PM
FloridaJag
11-18-2009 11:10 AM
