Blue tooth
I’m having trouble figuring out whether I have Bluetooth on my 2007 S-Type. Some paperwork says I do but I get a No Phone message. |
Hi There,
Check first that you have a Bluetooth Module installed in the car. It's located under the tray in the centre armrest which can be easily removed. The Bluetooth Module, if fitted, has a cable connector toward the rear of the compartment and the module itself is mounted on the right hand side and just underneath the lip the tray sits on when in place. If the module is there and connected try a pin test to see if there is power to the module. It may be worthwhile checking the Set Up menu to see if Bluetooth is 'enabled' before doing any of the above. Hope this helps. Cheers, Cubist |
I think you can have BT but no phone unless you provide/pair one. The full manual is online somewhere (or was).
hi
this is simple search for bluetooth devices, if you find Jaguar, your car has it, if theres no jaguar when you search you dont have its that simple bluetooth was no a cheap option, so most cars dont have it cheers Joe. |
Originally Posted by JaguarJacks
(Post 2011839)
That’s probably cause you got the older version Bro , get This particular edition (the latest) and see the difference |
