Can someone help walk me through diagnosing my fuel pump circuit problem?
Hello,
I have a 2006 S-Type, 3.0 V6. Great car. Once upon a time, I ran out of fuel. Ever since then, it has the following problem: The fuel gauge and Distance-to-Empty reading works fine from full tank to half a tank. When it gets down to half a tank (or sometimes less than half), the fuel gauge shuts off, there is no more DTE reading, a warning light comes on, and it gives the message "Fuel Pump Circuit Fault" (or Fuel Pump System Fault -- I forget exactly). From that point, I have a few more miles (maybe 10) until the car dies. It acts like it has run out of fuel. However there is still half a tank. However I have to add several gallons to get it to run again. It happens more on long trips; on short trips, it behaves normally all the way down to 1/8 of a tank. I speculate that whatever part is failing might be failing when it is warm from being in use.
Anyway, I know there are two pumps, one in each side of the tank. And I know there is a control module. And I know how to remove the pumps/sending units. And I know there is a screen I can make appear on the Sat Nav that gives the readings from the sending units, . . . but I don't remember how to get there or what the code is. I don't know which unit is number 1 and which is number 2. I don't know which one is the transfer pump and which one is the one that sends to the engine. And assuming for the moment it is one of the sending units that is bad, I don't know where is a good place to buy one at a fair price. There are multiple part numbers for each side, I can't tell which is which left or right, and I think there may be an early and late in 2006.
If anyone can help me, I really would appreciate it. I know there is a lot of information on the internet, but it is a bit overwhelming and too many places to look and sometimes conflicting information. I have spent hours reading over past months and haven't gotten the answers to the questions above.
Thank you,
Tony K.
Thank you,
Tony K.
Vehicles with the 3.0 litre unit fitted have one fuel pump located on the RH side of the fuel tank when viewed from the driver's position.
It appears you have a failing fuel pump. Has the fuel filter been replaced?
Thank you -- I've spent some time on jagrepair.com and don't see a factory service manual anywhere, and I can't find anything there that discusses the fuel pumps or fuel pump circuit as per above. Am I missing something?
Yes, the S-Type (and Lincoln LS have two pumps. One on each side of the saddle-shaped tank. Discussed here and elsewhere: https://www.jaguarforums.com/forum/s...-4-2-a-106285/
Thanks,
Tony
Thanks,
Tony
The sender are on both sides of the tank, drivers side is a jet pump that works to keep level even side to side and the engine pump that electrical is on the drivers side. Personally never seen your issue, but i would start by going into engineering mode in the instrument pack which shows raw numbers. Look at them when working correclty and then after it acts up and see if it still shows raw numbers. I would suspect you have a open in one of the senders and to diagnose youll have to pull out both and swing the arms up and down while monitoring the ohms will a dvom
Thank you, Ducmon. I am aware of swapping out the pump; but if it were just the pump, wouldn't it stall but still read half a tank? Doesn't the fact that the gauge goes to zero also indicate a sending unit issue? Are the resistance values of the sending units published anywhere? I'm guessing the side of the car with the fuel filler neck is the main pump and the opposite side is the jet pump -- is this correct?
Thanks again!
Thanks again!
Here is the link to the manual.
http://jagrepair.com/images/AutoRepairPhotos/CarPDFFiles/SType/S-Type%202002.5-2008-FSM-Workshop.pdf.
You can also get a
the electrical plans
http://jagrepair.com/images/AutoRepairPhotos/CarPDFFiles/SType/S-Type-Electrical-2006on.pdf
You can also get a
When you say driver side is the jet pump, are you referring to LHD / U.S. model?
Thanks!
http://jagrepair.com/images/AutoRepa...M-Workshop.pdf.
You can also get a
http://jagrepair.com/images/AutoRepa...cal-2006on.pdf
You can also get a
THANK YOU! Outstanding! I couldn't find it for some reason. Many thanks!
thank you, ducmon. I am aware of swapping out the pump; but if it were just the pump, wouldn't it stall but still read half a tank? Doesn't the fact that the gauge goes to zero also indicate a sending unit issue? Are the resistance values of the sending units published anywhere? I'm guessing the side of the car with the fuel filler neck is the main pump and the opposite side is the jet pump -- is this correct?
Thanks again!
Thanks again!
Engineering mode, press and hold the button on the turn signal switch then either turn the ignition on or you can start all while holding it in. Hold it in till goes into engineering mode, gauge sweep etc. Then you can cycle all through the different option by pressing the same switch repeatadly
David SD
Aug 14, 2015 03:20 PM
harryc
Dec 24, 2011 07:16 PM
Manofsteel
Aug 23, 2011 10:51 AM
