Refreshed the system , running smooth , ain’t no ‘check engine’ lights , thou this is what it shows on the screen Does anyone Know what we’re looking at ? |
An unwell car unless you fixed it and maybe it's relearning. Those trims look bad.
Probably it's unwell. |
Probably so ... It’s not shaking like it did , thou the fuel goes Fast what is it ? And if it’s the cats , what’s the most efficient and effective way to clean them ?? |
There is a product called cataclean that you pour in the fuel tank...I have used it before with success...your cats may be beyond help though if too much raw fuel went through them...I do not know how to physically inspect a cat converter....maybe using an infrared thermometer and comparing to heat specs
At least do the checks as for an air leak.
Originally Posted by JagV8
(Post 2012111)
Just lift the car up and look for a leak ? |
And I’ve noticed that when I turn the key for ignition it takes just a little longer to ignite than usual |
Originally Posted by JaguarJacks
(Post 2012127)
Note that any leak - exhaust or intake or evap or wherever - can be so small you cannot hear or see it. You must have no leaks at all.
DTC P0420 = replace catalytic converter after correcting over fueling fault(s) on Bank 1
DTC P0430 = replace catalytic converter after correcting over fueling fault(s) on Bank 2 There is no magic fix for failed catalysts with melted cores. Unburned fuel ignites inside the catalyst melting the honeycomb structure. |
(Post 2012142)
Sounds good Someone has also told me that after I’ve restarted the system by disconnecting the battery for awhile , it’s gonna go Rich on fuel before it adjusts itself into norm . Gentlemen , if that’s the case how long does it take for it to re adjust ? |
(Post 2013131)
(Post 2013131)
You can see it for yourself on a working car - yours isn't - as the trims start at zero. |
When it comes to the replacement ones, folks have used the Magnaflow 59975 ones (need to be welded by a shop).
Do you all know if there is a CA/CARB compliant version of those Magnaflows? Thanks so much, Jeff |
