Changed the spark plugs under the intake and now it’s shaking and on MIL
Old 01-26-2019, 06:24 PM
JaguarJacks's Avatar
Default Changed the spark plugs under the intake and now it’s shaking and on MIL
I think it could be the wiring cause when unplugging or plugging the upper intake switch it the same shaking
( I also slighting hit some harness wire with the wrench )
Old 01-26-2019, 08:53 PM
Ltd's Avatar
Ltd
Ltd is offline
If you get an OBDII code reader, it will give you the code for your check engine light. I forgot to plug in the MAF sensor after plug change and it was shaking badly. You will need to clear the code after you solve your issue.
ltd
Old 02-07-2019, 09:17 PM
Was a pure negligence of missing to reconnect one of the two vacuum hoses at the back
kr98664 (02-07-2019)
RichD
06-09-2016 01:45 AM
arath25
09-01-2014 07:23 AM
Mihvv2007
11-24-2013 03:04 PM
rhriczko
04-21-2011 07:42 PM
Quick Reply: Changed the spark plugs under the intake and now it’s shaking and on MIL
