Cheap New Interior Plastics
I am hopeful that my new-2-me 2002 S-type will have a smooth running transmission again tomorrow. (It's in the shop now and trans mechanic is pretty certain the parts to repair the lack of 4&5th gears will be in tomorrow.)
Once that is fixed, there are just a few small interior problems I would like to correct. The AC vent to the left of the steering column has a little problem. It is warn and the directional grate seems to be a slight bit broken. Is there a relatively inexpensive place to buy replacement parts like that? Please sayyes... (Don't bother to say "Sorry, it's a Jag!" OK, you can say it IF you must! ;) Thanks, Greg |
RE: Cheap New Interior Plastics
Here is a link to a place that I've used in the past. It's a Jag/Porsche dealer, but the pricing is usually lower than getting from you local dealer. The link is for the outer vents (#11 as selected in the link)
http://tinyurl.com/b8ceml HTH, Mike <edit> shortened URL with tinyurl.com </edit> You can also try these guys - used them also. http://www.coventrywest.com/ <edit> added another source </edit> |
Any other ideas for inexpensive OEM or replacement plastics for interior... or other parts? All suggestions welcomed!
