Connecting Bluetooth
Hello everyone..
So I want to hook up my bluetooth to my 2005 jaguar S-Type R got any advice?? my phone comes with the blue tooth hook up i search for a connection and the car does not get picked up... you guys got any advice? |
Are you talking about "pairing" your Bluetooth phone to the car? This needs to be done first.
Eric |
Yes if that is what has to be done, how do i do this?? Ive used bluetooth before so i know how to connect to other phones....but what i need help on is gettin my car to show up on phone i do not know what button needs to be pushed to connect the two
This is for my car (2005 S-Type) and my phone (Blackberry 8330). If it doesn't work for you, it will give you an idea.
************* Car: Enter ##3#*# using the keypad and press the green Send/End icon (“Discover me” appears on the screen) Phone: Select "Options" Select "Settings" Select "Bluetooth" Select "Add device" Highlight Jaguar Enter PIN 1313 and press "OK" NOTE: During pairing please use the PIN 1313. I also have the option of using ##1#*# as the pairing commend. This one won't time out whereas the one using the "3" times-out after about 5 minutes. ************* Once you've paired the two, they should link up automatically when you get in the car and turn on the ignition. There's a book available. Check: http://www.jaguar.com/us/en/#/owner_...ent_literature Eric |
Do all 2005 S-types have this? I do not have a R.
1 Attachment(s)
Originally Posted by DBR
(Post 145092)
Here is a picture of the microphone, it's the little box next to the overhead console. |
Originally Posted by Toller
(Post 144909)
************* Car: Enter ##3#*# using the keypad and press the green Send/End icon (“Discover me” appears on the screen) Phone: Select "Options" Select "Settings" Select "Bluetooth" Select "Add device" Highlight Jaguar Enter PIN 1313 and press "OK" NOTE: During pairing please use the PIN 1313. I also have the option of using ##1#*# as the pairing commend. This one won't time out whereas the one using the "3" times-out after about 5 minutes. ************* Once you've paired the two, they should link up automatically when you get in the car and turn on the ignition. There's a book available. Check: http://www.jaguar.com/us/en/#/owner_...ent_literature Eric OK I Also have a blackberry so all this should work, just one question how do i get to the keypad section on the car?? I have the mic in my car so im assuming i should have the same setup as you |
Originally Posted by jkosko
(Post 145141)
when i hit that it tells me "Phone Not Fitted"
"This system does not have a phone fitted" |
(Post 145170)
"This system does not have a phone fitted" Mine came with a seperate owners manual just for the Blue tooth install. You might drop by your nearest dealer and ask them, I am sure they will let you know for no charge. |
(Post 145170)
"This system does not have a phone fitted" Oh yea, another question, is there a plug and bracket on the underside of your center console door? If there is, then you have the phone module but not the bluetooth module.... I thought all 05's were set up for bluetooth if the phone was installed, but that may not be true... |
Maybe we need to confirm that your car has a Bluetooth capability.
In the head lining above the driver and passenger there are two small (smaller than a dime as I recall) circular vented openings. Those are not the Bluetooth microphone. Instead, above the driver's head is a surface mounted component that is longer than it is wide or height. That's the microphone. Eric |
Yes I do have the speakers I saw the picture that was posted and it is exactly what my car looks like I believe I need to get the bluetooth enabled or get the hook up
(Post 145264)
The round vented things aren't speakers. If you don't have the surface mounted object that is about an 1 1/2 inches long by 1/2 in wide and sticking below the headliner by about a 1/2 inch, you don't have Bluetooth. That's the microphone. It'll be easier to tell if Bluetooth is installed from that than from removing the console.
The speakers used are also the entertainment speakers I believe. Eric |
(Post 145141)
My apologies. I didn't see the photo message and he referred to "speakers."
It is certainly strange that the physical evidence (microphone) of Bluetooth is there yet he's getting the message that it's not installed. Why would anyone install the one and not the rest of the system? Curiouser and curiouser.... Eric |
(Post 145557)
It is certainly strange that the physical evidence (microphone) of Bluetooth is there yet he's getting the message that it's not installed. Why would anyone install the one and not the rest of the system? Curiouser and curiouser.... Eric And no apologies necessary. I've done a bunch of research on the phone system since that is the one thing I wanted to add. But way more money than I'm willing to spend. Got the SIRIUS system for 50 bucks. Works OK. I also have a Blueant speaker phone for now. |
I have the same problem. I have a 2005 S-type, the voice command button only does MUTE. And every time I push the PHONE Button, the screen shows "no phone fitted"! I am pretty sure there's a microphone above the screen.
Japson - you almost for sure have no phone. Did you look at older posts to see if you're right about what's above the screen? There's a fair chance you're not :(
| All times are GMT -5. The time now is 10:46 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
