Coolant reservoir tank replacment
#121
Jon89 (10-10-2018)
#122
From what I have heard, Meyle is a pretty well regarded aftermarket supplier of the tanks, but Uro is to be avoided as being of inferior quality. This is from internet posts observed and discussions with the owner of the shop that works on my S-type and Mercedes.
I just had a Meyle tank installed in my car as the sensor in the old tank had failed.
#123
Key is don't lose the clip from the quick-connect. I'd do the quick-connect last, after the elec. connector and if you have the right size vinyl cap laying around (I did) coolant loss will be very minimal....pull the QC and slap your thumb over the tank port (assuming no proper size cap) and you won't lose much. Makes a nice spout for transferring the coolant remaining in your cracked tank into the new one after install. After you install the new tank....make sure you tug on the lower hose quck-connect and wiggle at it to make sure it is properly seated. You won't make it out of the neighborhood without a bunch of steaming stink if you screw that one up so you should be good-to-go ar far as the KY trip.
Dealer charged me $108 for the 3.0L version. Ask for a discount if yours is higher. (He SURELY won't sell it for less if you fork over whatever he's asking)
#125
Just did the replacement of the expansion tank , and lost the metal fastener of the bottom hose to the engine bay , anybody knows how to fasten this hose properly or get this metal clip ??
#126
Get in there with a magnet and strong flashlight and look around. If you have your belly pan fastened to the bottom of the car - remove it and you'll probably find it settled there...
Simon99 (05-10-2020)
#127
Heed the warnings above!! We have had a forum member burn up his engine because the clip was not properly installed!
When it blows you lose so much coolant so fast you don't have any time to shut it down before it's all over.
I pull and tug on that hose until I am positive it's clicked and holding properly.
No the clip is NOT serviced separately and several people have fought this as they lost the clip too.
#128
Thanks for the sweet advice , just grabbed it with the a flashlight and a long stick magnet at the bottom of the tray , eazy , so good .
Norri (05-15-2020)
#129
#130
#133
Go with OEM. They don't last forever. You get a few years at best. Chinese crap is junk right out of the box
NBCat (01-11-2023)
#134
KarimPA
09-03-2015 07:32 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
