Do you guys w/ H&R lowering springs have rapid inner tire wear?
Old Oct 16, 2011 | 01:25 PM
Under Pressure's Avatar
Default Do you guys w/ H&R lowering springs have rapid inner tire wear?
It does not appear anyone makes camber kits for the S-Type R. I have only had mine for two weeks so perhaps I just haven't found of a company that does make them yet and maybe I'm just wrong. But if I'm right and no one makes camber kits, aren't you guys with lowering springs burning through tires by wearing out the insides?
Old Oct 16, 2011 | 01:49 PM
JagV8's Avatar
Why a kit? Why not just adjust the camber? Is it not adjustable enough?
Old Oct 16, 2011 | 03:05 PM
Bacardi 151's Avatar
https://www.jaguarforums.com/forum/s...e4/#post190615 Post 71 has the revised alignment specs...S-Types were notorious for excessive inner tire wear in stock form; I can't offer any info/advice to lowering springs, but assume getting the revised/updated alignment specs will do more good than harm...
Old Oct 16, 2011 | 06:52 PM
Michael Star's Avatar
Nope, had my h&r springs on since the first of the year.
Old Oct 16, 2011 | 07:02 PM
Good to know Michael Star. It seems some vehicles are more prone to extreme negative camber issues via lowering springs causing the bottom of the wheels to bow out, leaving only the inner edge contacting the road and therefore wearing rapidly. On two of my previous Mercedes' on H&R's that had no camber kits installed, I would burn through tires in about 5k miles or so, and that got very expensive. But then on my old WRX, I had no problems. According to my old neighbor who had a lowered B6 chassis Audi S4, he did not have extreme negative camber issues either. But on my old Mercedes', they were so bad that they couldn't be corrected without a camber kit because the factory adjustments were not long enough to dial them back in.
Old Oct 16, 2011 | 07:18 PM
I think Brutal made some comments on alignment with lowered springs recently, might be worth a search.
Old Oct 16, 2011 | 08:44 PM
Ya, as soon as I had the springs installed, I took Brutal's instructions to Firestone to get an alignment done.
Old Oct 17, 2011 | 01:10 AM
jag79's Avatar
By any chance do still have brutals instructions on hand to share? I'm having some problems retrieving them. Thanx.
Old Oct 17, 2011 | 02:24 AM
JagV8's Avatar
Go to Advanced Search
put
alignment (in keyword)
Brutal (in member)
select this forum
select Posts (instead of Threads)
and up comes what you want
Old Oct 17, 2011 | 08:22 AM
Brutal's Avatar
Originally Posted by jagv8
go to advanced search
put
brutal (in member)
select this forum
select posts (instead of threads)
and then sometimes he just trolls though threads searching for alignment key words..........
Old Oct 17, 2011 | 09:14 AM
Have you tried the FAQ under alignment? (Since yesterday)
Old Oct 17, 2011 | 09:29 AM
jag79's Avatar
Nevermind I found it. I was using my iPhone at the time when I posted for help; must have overlooked it, but anyhow thanks to Brutal and all for the useful info to share.
MrWhite
19
Jun 14, 2022 07:49 PM
Johnken
Apr 8, 2018 10:21 AM
MrWhite
33
Oct 22, 2015 10:29 AM
RedRider48
Oct 1, 2015 08:18 AM
JagBrian
Oct 1, 2015 12:52 AM
