Does anyone know where the crankshaft sensor is located on a 2004 s type v6
Spent two hours looking for it. I also searched online but can't find the location of the crankshaft sensor for a 2004 s type v6.
Appreciate any help...thanks |
Move to S-Type forum and get the free workshop manual.
Welcome to the forums adamsavey,
I've moved your question from General Tech Help to S-Type forum. This is the place to post technical questions about your model. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
1 Attachment(s)
The CKPS is on the right forward side of the engine block. The electrical connector is shown on page 40 of the S-Type powertrain into booklet S-Type POWERTRAIN_JJM101517-92.pdf
Crankshaft Position (CKP) Sensor Crankshaft position and rotational speed are sensed from a steel timing ring keyed to the front end of the crankshaft immediately behind the front cover. The timing ring has 36-1 teeth, ie one missing tooth, which are angled slightly forward and bent at right angles to provide a sensing area for the inductive sensor. The sensor is positioned in the front cover, to the side of the crankshaft damper, at approximately 20 degrees to the plane of the timing ring. |
thanks
Originally Posted by JagV8
(Post 2094767)
Thanks so much!
As a newbie you won't yet be able to download the very useful attachment motorcarman included in his post #4.
Here's the engine control locations graphic from the Workshop Manual: https://cimg9.ibsrv.net/gimg/www.jag...52aaf0a972.jpg See item 7. Graham |
Graham...thank you so much, that helps even more since I wasn't sure I had the right spot. Have a great day!
