Dsc not supported / abs fault / gearbox fault
Old Apr 15, 2012 | 03:38 AM
Nelsters's Avatar
Angry Dsc not supported / abs fault / gearbox fault
Hi guys i am new to this so i hope i get it right
i have a 2004 jaguar s-type cw v6 auto this morning i drove my car as normal and three fault appeared DSC not supported / abs fault / gearbox fault.
gearbox seems to be stuck in one gear only as you set off driving when d is selected it clunks then as you drive off, its as if you have put the brakes on for a second then it drives off ok, but the faults are just on display and picks up slowley but no misfire and drives like a train when speed is up any help please
Old Apr 15, 2012 | 04:32 AM
jaglover922's Avatar
Sounds like a throttle body fault
Old Apr 15, 2012 | 07:39 AM
bfsgross's Avatar
Check condition of the battery. Though it may start the engine, a weak cell will not bring it up to par with the needs of the complex electrical system. Also, if you recently ran into high moisture conditions, the electrical connections, especially the throttle body harness are finicky in these conditions. Check battery then report back.
Old Apr 15, 2012 | 09:38 AM
Nelsters's Avatar
Battery condition is fine
Old Apr 15, 2012 | 10:26 AM
abonano's Avatar
Since you report the battery is good then your next course of action would be to pull any codes from the transmission and ABS computers. You will need specific software/equipment to access these modules. if you do pull codes do post them. Good Luck.
Old Apr 18, 2012 | 03:49 PM
Nelsters's Avatar
Fault code are p0731, p0701, c1175 please tell me what they are please
Old Apr 18, 2012 | 03:54 PM
JagV8's Avatar
With so few posts and no upgrade (you appear not to have posted in the new member forum), you probably can't get the codes PDFs which have lots of detail for each one. But have a try as it's well worth it - or post an intro
Or... get JTIS.
Main thing they have in common strikes me as power or problems with it, that is the battery.
Old Apr 18, 2012 | 04:51 PM
Sounds like you are going to need to find some info, so JagV8's advice about posting an intro may well provide benefits if the admin upgrades you.
cissdm
May 3, 2016 06:02 AM
Marco Polo
Oct 1, 2015 07:13 PM
xjrjag
Sep 24, 2015 10:08 PM
swetnK
Sep 24, 2015 07:55 AM
