ELM 327
Hi Jaguar people,
Has anyone had any experience with TOAD OBD2 software that bluetooths to Samsung android devices/smart phoes etc. I have been told its got more depth than icarsoft i930 but have no idea myself. I am particularly searching for 2001 S Type V6 door security problem codes. Hope someone can help. Cheers, Steve. |
Originally Posted by sgroves_69
(Post 2007804)
Hi Jaguar people,
Hi Scottjh9,
Thank you for the thread reply and as your fault is the same as mine with a ddm problem I will order an i930. Can you tune your fuel performance with the i930 as well? My door security probs are weird, #1 on drive-away I can hear the doors lock and then they immediately unlock. #2 with the fob they do the same except if I double click lock, the front LH passenger door and the rear RH passenger door remain able to be opened and the alarm goes off.???!!! The boot (trunk) always works fine. I have worked hard since I bought her a year ago and these pesky little faults are the only thing wrong with a beautiful machine. Thanks again, Steve. |
(Post 2008056)
Hi Scottjh9,
Thanks Scottjh9,
I guess its common sense to do as you advise. When I get the i930 I will "read" the codes first before ripping off any modules. Cheers. Steve |
Just a thought...on my 06 everything door wise is controlled by a single module in the driver's door... maybe your year car has one in the passenger door to control the passenger side and it has failed... hopefully someone with a pre 2002.5 will chime in as I am not familiar with your vehicle specifics
