Emergency Brake Fault
I start the car and I get a emergency brake fault. It will not let the car move freely. How can you clear this or what might be causing it. I have started car, shut it off let it reset and started again and got the same fault.
It might be simple try this.........
Re-Calibration Procedure 2003 MY-ON S-TYPE M44998-ON Issue: On some 2003 MY-on S-TYPE vehicles, a customer may report a concern of premature parking brake pad wear or the brakes binding. This condition can result if the electronic park brake (EPB) system is not re-calibrated after the removal of the rear brake calipers to replace the brake pads. Action: Should a customer express concern regarding the above, refer to the calibration procedure detailed in this bulletin. 1. Reset the EPB module: a. Switch off the ignition. b. Disconnect the battery for 30 seconds. For additional information, refer to STYPE Workshop Manual Section 414-01. c. Reconnect the battery. 2. Start the engine. 3. Firmly apply and release the footbrake five times. 4. Confirm that the message ‘NOT CALIBRATED’ or ‘APPLY FOOT AND PARK BRAKE’ is displayed on the instrument cluster message center. This indicates that the parking brake is in calibration mode. 5. Lightly press the footbrake pedal. 6. Apply the parking brake by using the EPB switch. 7. Release the parking brake. 8. Release the footbrake. 9. Confirm that the brake warning lamp is no longer illuminated on the instrument pack and that the ‘NOT CALIBRATED’ message is no longer displayed in the message center. 10. Apply and release the EPB five times to ensure no error is present. |
