engine stops above 2100 rpms - code P1586
HELP! Jaguar shop mechanic completely confused --
Any thoughts????
this message is from jag owner who began this thread.
My Jaguar is in Los Angeles official Jaguar Dealer service center
Service tech Attempting to clear a P1586 code. .. told this to service manager......
Service tech told service manager ..
"no progress on download.
No coms (communication) with ECU"
"Think it (2001 S-type v6) may have a frozen task bar"
Any ideas or thoughts?
they are stymied.
they are stymied.
Any thoughts????
they are stymied.
they are stymied.
hello LAjag
I have a digital workshop manual on my computer for the s type from 2002.5 to 2008...I downloaded it from this forum...I run windows 7...I live about 175 miles north of you in the central valley...I will gladly load it onto a thumb drive and mail it to you if you like if you still need it...i know you are working on a 2001 but this manual might help if you cannot load it yourself from the forum link....let me know...I could mail as soon as tomorrow
LAjag (05-30-2018)
LAjag (05-30-2018)
Received 2,577 Likes
Here is a link to the Workshop Manual for the pre-facelift cars:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
Same one as already on here and JagRepair.com - Jaguar Repair Information Resource probably.
LAjag (05-30-2018)
#28
Thanks to all of you....
just now getting back to this forum page...
Thanks for the S-type Service Manual links.
frustrating issue...
frustrating as well.. because also, seems we have to "educate" the Official Jaguar service techs.
Your answers were same as mine.. so I texted service manager..
"sounds like tech let battery get too low during the download. Because download will effect several modules, if current drops before finishing, some modules will be reprogrammed and others not...causing a variety of unknowns. Charger needs to be set at 13 -13.6 volts."
#31
NBCat (05-31-2018)
#32
Take it to NB Cat. He can't be far from LA if that's where you are.
#33
a real headache
What would cause PCM to not recognize throttle body?
I swapped throttle body for another, and still have same P1586 DTC fault code.
Did continuity check on all wires between false bulkhead connector and TB connector. all seems fine.
week #2 at Jaguar Dealer service center in Los Angeles..
no progress...
Jaguar forum members are by far better suited than Official Jaguar Service center for discovery of answer to this puzzle.
Thanks again for your ideas.
no progress...
#34
If the part is correct for your car, I wonder if it is defective. For all we know, the donor car may have been getting the same P1586 code before ending up in the wrecking yard.
As mentioned in a previous post, my '02 V6 had been occasionally throwing a similar P1584 code. I forget the exact details, but I'd suspect the fault is close to your code. A guaranteed used throttle body ($75) from eBay put the fault to rest, never to return. If you can find a similar deal, that might be worth a shot in case the donor part was bad.
#35
Also note the clever way I left blame pre-assigned in case it doesn't help...
#36
Believe my problem is in white "W" (Actual Throttle Angle) input to PCM.
White wire gave an odd positive reading .. neither 1 nor 0
All wires tested good for continuity, except white wire.
"W" white wire seems to run from throttle body plug directly to
(located on right firewall)
Per section 3.1 of the wiring diagrams, that wire is a straight shot from the TACM to the PCM. Assuming it's buried inside a big harness, and the fault is confirmed, you could splice in a new wire at each end and run it on the outside. That would be way easier than tearing the entire harness apart in search of one bad spot.
#37
Last but not least, did you try swapping this relay? This had been previously xuggested, but no mention if you actually tried it. Find a non-essential circuit with the same relay. Make sure that circuit works properly to confirm the donor relay is good.
LAjag (06-25-2018)
#38
Response question by kr98664
Among first things done...
swap relays
check fuses
disconnect battery... perform hard reset
continuity check wiring --between throttle body to PCM plug at false bulkhead (rt)
swap throttle body for used TB from similar car witb same eng size
Still in "limp mode"
As last resort .. sent car to dealer to reprogram PCM...
swap relays
check fuses
Last edited by LAjag; 06-25-2018 at 05:00 PM. Reason: need intended recipient information added
#39
response to kr98664
No... you misunderstood.
found odd reading on continuity ck white white wire. ... (note: probably issue with my test)
TO be certain of continuity... as you can read previously...
I created a new connection to bypass that wire with a new wire and new wire tested fine
Without any apparent change in engine, nor throttle Body
Last edited by LAjag; 06-25-2018 at 04:58 PM. Reason: need intended recipient information added
#40
A quick look here shows different part numbers for the 3.0 depending on the model year (actually by VIN). Scroll down near the bottom of the page:
Throttle body part numbers
Up to 2002 takes p/n XR858418.
2003-2005 takes p/n XR845053.
LAjag (06-26-2018)
