Full Jaguar EPC for download - Now with step by step install instructions!
Brought to you by BuckMR2, hosted by me.
[added by h20boy]--------- Jaguar Electronic Parts Catalogue (JEPC) latest revision 11/2008 All models, all years up to 2008 (at least that is what my CD says) --------------------------- Please don't link this to other sites or be ridiculous, this is on one of my personal servers. About 50mbps Bandwidth. Completely Editied now with screenshots and step by step install instructions. These instructions are for windows 7 32 bit. No difference in 64 bit EXCEPT you have to enable the 32bit browser as default! First, before downloading the file, you need to make sure you have winrar installed. This is the program that you will use to extract the files to your computer. You can get winrar free of charge from here: IF you have a 32 bit operating system, Click on this link: http://www.rarlab.com/rar/wrar393.exe IF you have a 64 bit operating system, click on this link: http://www.rarlab.com/rar/winrar-x64-393.exe Once you have winrar Installed, click on the link to download the EPC.rar file: http://www.itprosondemand.com/jaguar/EPC.rar Save the file to your desktop just for convenience. You will be deleting this file when you are finished. Once the download has finished you will see the following icon on your desktop: http://www.itprosondemand.com/images/icon.jpg IF the icon doesn’t look like that (The 3 books stacked like that), you have not properly installed winrar, you need to repeat step one. Double Click on the EPC.rar icon and winrar will open, at first at the lower left you will see it counting files, once it is done, you will get a menu that this is a trial version, just click on close. Then You will see this: http://www.itprosondemand.com/images/winrar.jpg Click on the extract to on the top left: http://www.itprosondemand.com/images/extract.jpg The extraction path and options menu will come up – leave the defaults and say OK. http://www.itprosondemand.com/images/extractmenu.jpg This will pop up and it will extract the files – this may take a little while http://www.itprosondemand.com/images/extracting.jpg Once the extraction has finished close winrar. You will have the following icon on your desktop: http://www.itprosondemand.com/images/EPCfolder.jpg Double click on that folder and you will see the following folder: http://www.itprosondemand.com/images/1st%20Level.jpg Double click on the folder “Jaguar Epc v3 10.2009” You will see the following window: http://www.itprosondemand.com/images/2folders.jpg First take the JEPC Shortcut file and drag it to your desktop. Then CLICK on the JEPC folder, hold down control and click on the jepcv3 folder (so both are highlighted). Right click and say CUT. (or press control X) http://www.itprosondemand.com/images/cut.jpg Now go to computer (or My computer in XP) http://www.itprosondemand.com/images/computer.jpg Double click on c: You want to be in the root of c: (your icons will be different, BUT the key is across the top that it says computer -> Local Disk (C: ) -> Right click on a blank part of the window and say paste: http://www.itprosondemand.com/images/paste.jpg The computer will move the two folders from your desktop to the c: directory http://www.itprosondemand.com/images/moving.jpg When it’s done you should see these two folders in the computer -> Local Disk (C: ) -> window. http://www.itprosondemand.com/images/copied.jpg Now double click on your JEPC Shortcut icon on your desktop: http://www.itprosondemand.com/images/jepcicon.jpg IF all went well this will open up. http://www.itprosondemand.com/images/login%20page.jpg Type Admin in the login field and 123 in the password field - click login, and the main menu will come up: http://www.itprosondemand.com/images/main%20menu.jpg Then select the model / year, and go from there. Hope this helps with all the install issues. Feel free to ask a question if you have one or need help, BUT please post it here, that way I don't have to answer the same questions repeatedly, and others can read it here rather than waiting for me or others to respond. Take care and Enjoy George |
Downloading now, Thanks!
Downloading...
As per our conversation...You can use my CD if you wish for the JTIS..Just let me know... Thanks a lot, George.. |
Not to be stupid but what the heck is an EPR?
Originally Posted by Enthusiast
(Post 289375)
You can have the same software the dealer has for looking up parts on your PC. Download this if you work on your car. Josworth - I'll PM you regarding JTIS etc. Here's a screenshot: https://www.jaguarforums.com/forum/a...1&d=1294278319 Take care, George |
I don't seem to be able to get the files to work. I'm running W7 and when I launch the shortcut some text flashes on the screen then nothing happens. It happens so fast I can't read what it's saying...
The files all extracted fine and they are in c: Any ideas? Thanks! |
Originally Posted by cacloss
(Post 289431)
The files all extracted fine and they are in c: Any ideas? Thanks! Or Two driectories in C: JEPC and jepcv3 If you have one, you need to copy the two directories mentioned above out of that one onto c: Also you on 64 bit or 32 bit 7? George |
Works just fine on Windows 7 64 bit. The confusion might be as to which file is used as the desktop icon.
Originally Posted by Mikey
(Post 289447)
Btw the pics are flash based, so you prob have the 32bit browser set as default if you are working. George |
Brilliant!
Would it work with Apple Mac?
Originally Posted by Zenman63
(Post 289485)
As long as you put those two folders in the root forec Probably worth a try... worse case you delete the files. George |
Nice one George/Buck, thanks for the XMAS pressie. :)
Much appreciated and looks as if this will be really useful - but I can't get past the logon page. Am using the ADMIN/123 as per readme.txt. Any ideas?
Originally Posted by androulakis
(Post 289122)
Brought to you by BuckMR2, hosted by me. See X-Type section for origins / instructions.
Please don't link this to other sites or be ridiculous, this is on one of my personal servers. About 50mbps Bandwidth. http://www.itprosondemand.com/jaguar/EPC.rar Have fun! Anyone who has an uploadable copy of JTIS, I can host that too. PM for details. Take care, George |
Originally Posted by fergs03R
(Post 289606)
have win 7 64 and it downloaded as a pdf and it wont open, Iget a message that its not supported or its damaged
Just click on the link, and it should ask if you want to open it or save it. To the other Poster, yes, Admin and 123 work. May want to try Lower case or Capital A. To the guy with the mac - I saw you downloaded it, I'm actually really curious to see what happens. George |
(Post 289634)
Install the x64 bit version of Winrar first, so it registers the filetype, then download it.
(Post 289606)
Get WinRAR or any unrar. The clue's in the .rar file name :) |
Originally Posted by colinb
(Post 289601)
LOL... Love my XP laptop...
Downloaded and opened with Winrar... Dragged the two folders to C: (no directory) then dragged the shortcut to my desktop.. Click.. ADMIN / 123 and all opens fine.. Really great find George... Thanks a million... |
