gearbox fault
I have a 3.0 v6 1999 model s type. I parked up at a friends house and when I wanted to set off again I could not select drive, reverse or anything. Does anyone know what it may be.
Thankyou all in advance. |
Stretched shifter cable, failed interlock microswitch, parked on incline without first applying handbrake. Some searching and reading ahead for you.
Does the gear selector move?
+1 to JagV8 - my guess would be the shifter block (plastic) snapped.
This happened to me you'll need to take apart the center console and basically remove everything I found a nut on a pin underneath the shifter backed off and a spring and small ball fell down I put everything back together with a little locktite and it's worked fine since
| All times are GMT -5. The time now is 01:33 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
