Help OBD2 codes o2 camshaft sensors?
Hi guys i'm fairly new here but have been reading the boards for a while. I have solved a bunch of problems thanks to you guys but i'm in a bind now. Alright, so I hooked up my OBD2 and came up with these codes.
P1380-Misfire/Rough Road Bank1-Camshaft Sensor?
P0174-System Too Lean Bank 2-MAF?
P1131-Lack of H02s sensor Lean
P1151-Lack of H02S1 Lean
Now I know your going to tell me the search button is my friend and that is true lol. It has been my friend in the past but now I'm stomped. It runs really rough and when I first start it up it idles hard then suppresses after about 30 seconds. I really would appreciate help guys.
It happens!
Your codes look to be wrongly converted from numbers to words. Where did you look them up? Be sure to change to using jag S-Type codes and of your car year etc. JTIS has them.
I can't copy & paste so these are hints
P1131 (O2 fault)
P1151 (O2 fault)
P1380 (VVT solenoid fault)
P1131 (O2 fault)
P1151 (O2 fault)
Well I looked up the codes on OBD-codes.com and searched around here for what I could find. I looked under my hood and it looks like i have no camshaft sensor on the passenger side but im still confused on which O2 sensors to change.
That site gave you the wrong meanings.
I wouldn't change things without the proper jag meanings and jag assistance about them, both are in JTIS. You could spend $$$ changing the wrong parts.
Marka
22
Sep 11, 2016 12:09 AM
