Hesitation going uphill
2002 S-type 4.0, 115K miles: Feel hesitations going uphill at constant or slight increase in speed. Downshift to 4th and it goes away. BUT, if I use cruise control, no hesitation whatsoever at constant or increase in speed. No other issues; no reduction in mpg. Your insights are appreciated.
+1 on misfiring coils. The spark plugs should also be replaced at that number of miles if they have not been replaced recently.
Check the condition of the cam cover gasket and spark plug seals for signs of leakage as oil contamination into the spark plug wells can lead to shorted coils and misfiring.
Who knows but more likely coils than plugs. Do not use the wrong plugs or expect worse troubles.
The owner's manual may also contain the specification for the spark plugs, or you can purchase plugs with the correct heat range from a local Jaguar agency.
Should really consider having the codes read at any big box auto parts store for free, then post the actual pending codes here.
Unless you have a blooming money tree in the back yard to start throwing money at guesses!
Thanks. Just checked with scanner and came up with pending PO303. Also, no check engine light. From reading some other comments, this seems to usually be the coil. Should be easy enough to replace and retest. What do you think?
Pull the #3 CP and switch it with another and see if the code jumps to that cylinder.
When pulling the COP, as mentioned above take a peek around for oil collecting in the spark plug well or on/around the COP boot.
You should have handled it when you replaced the COP. It is very easy to change out the cam cover and spark plug well seals when you have the plenum off.
Oh well live and learn.
Yea, it was all fine at the time I did the left side so I didn't. Thankfully I still have the right side gasket from the kit that included both. I was going to sell it, but it didn't! Whew. But as you say live an learn and it goes faster the 27th time around!
