Inherited NA S type with a bunch of issues
Old Sep 11, 2015 | 07:11 PM
Toybreaker's Avatar
The engine is not knocking. Didn't think about just plugging in the new one....
Too late, the old one is already in the trash.
Consistent p0327 P1000 after clearing.
I'll finish assembling it and test drive it today and report back.
Old Dec 1, 2015 | 06:50 PM
Toybreaker's Avatar
Ok lots more issues.... new thread time.
Old Dec 4, 2015 | 08:32 AM
Marc's Avatar
You mentioned the rpms were only about 2500. With fly by wire, this is usually what the engine will rev when out of gear. Rolling in gear on the road, it should turn about 6,000.
Old Dec 5, 2015 | 05:57 PM
Toybreaker's Avatar
Yeah and under load it only pulls to 2500 then the ses starts flashing and running like absolute ****
Old Dec 6, 2015 | 09:14 AM
JagV8's Avatar
If that's the MIL then it's saying misfires so bad they're cat-damaging then and there.
Old Dec 6, 2015 | 03:45 PM
Toybreaker's Avatar
Yeah, Code stored after that is P1316 or whatever the cat killer is.
And why is it doing it?
I have to reload my scanner onto my laptop to get live data stream back to check the fuel trims....
Old Dec 6, 2015 | 04:33 PM
JagV8's Avatar
Then you can check if it's a leak and if so go hunting for it.
Old Dec 6, 2015 | 06:07 PM
  #28
Toybreaker's Avatar
I have done a smoke test, as well as test with brake cleaner. no indications of a break in the intake tract after the MAF.
Old Dec 7, 2015 | 01:28 AM
JagV8's Avatar
But what do the trims show?
Old Dec 7, 2015 | 09:09 PM
  #30
Toybreaker's Avatar
https://www.jaguarforums.com/forum/s...-4-2-a-154102/
Going to continue this line of troubleshooting/repair on this thread.
Old Dec 8, 2015 | 07:25 AM
  #31
Marc's Avatar
Ditto on the fuel trims for me Toybreaker. Lucky for me most all of my rough running issues on our 2 Jags thru the years were resolved with the replacement of one or more ignition coils, zip tieing the connectors here and there, (mainly the throttle motor). and re-timing and associated repairs to the exhaust cam left bank.
A quick check thru the Jag engine stalling reference reminded me of the importance of having the right spark plugs. If the OHM is different, the PCM, ECM ECU whatever, won't read correctly. The other thing comes to mind is the sealing of the air boxes, since the flow thru dictates the fuel and spark delivery. Something else that seems to mess with peoples heads is the grounding of the battery to the engine block and particular sensors. I have seen grounds contribute more than their fair share of weirdness. Just because they crank over, might not mean good enough. Sorry If I am repeating what anybody else has already stated.
Old Dec 8, 2015 | 04:50 PM
  #32
Draven's Avatar
Default Battery and TPS
What kind of battery did you get???????
Old Dec 8, 2015 | 04:52 PM
  #33
Draven's Avatar
And what is your voltage on the TPS
stanjag
Dec 29, 2024 08:26 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
ControlIssues
Sep 3, 2015 07:38 PM
ogorir
Sep 3, 2015 07:34 PM
RayJackson
XK120 XK140 XK150
Aug 31, 2015 09:39 AM
