Jaguar S-Type Rattling Noise in cold Start
Old Jan 19, 2016 | 06:43 AM
Rajamogan's Avatar
Default Jaguar S-Type Rattling Noise in cold Start
Hi All, Greetings from Singapore,
I have a problem with my Jaguar S-Type 2.5L 2005 model, everything was fine until I did my oil change 2 month ago. What my workshop did was, flush my engine before oil change and fill with 5w30, Thing was great when I left the workshop.
But when I start my engine after its been sitting overnight or for a few days, I hear this rattling noise coming from the engine and it goes away after about 10 seconds.I went back to the mechanic, but he was not able to help me. After a month I had my oil change again, but the rattling noise is still there.
I read through this forum that it could be the VVT Unit, what I don't understand is what is the VVT unit, Is it the Camshaft Adjuster Magnet or the Camshaft Timing Solenoid Sensor. Which one do I have to replace. Help please.
Old Jan 19, 2016 | 07:43 AM
Welcome to the forum Rajamogan,
I've moved your question from Jaguar Forums Feedback & Suggestion Center to S-Type forum. Members here with the same model will be able to help.
It's a long time since joining for you to be making your first post! Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 19, 2016 | 11:00 AM
kr98664's Avatar
Welcome! You will find many knowledgeable and helpful members on this forum. I'm here, too
Before you go into full panic mode, there may be a simple fix. Could be 5W-30 oil is too thin for your climate, especially if the engine has high mileage. I'd try switching to the heaviest grade specified for your car and see if that helps. On my '02 3.0 V6 (250,000 miles), I tried running 5W-20 and started getting an intermittent fault code for the VVT system. I then switched to 10W-40 and all has been well since then.
With any luck, the fix could be that simple. And next time somebody suggests an engine (or transmission) flush, tell them ,"NO!" Sadly, I've heard too many stories of new problems starting after a flush stirred up old sludge. Normal amounts of sludge won't hurt anything, sitting harmlessly in the bottom of the oil pan.
Keep us posted
adpock
F-Pace (X761) / C-X17
Aug 22, 2016 09:22 PM
BJG
Dec 20, 2015 04:44 PM
OMGPirate
Motorsports
Dec 16, 2015 09:21 PM
uncheel
Dec 15, 2015 06:37 PM
Jaguar Forums Editor
Jaguar Press release
Dec 11, 2015 09:38 AM
