Key fob battery replacement write-up...FAQ
Old Oct 19, 2014 | 02:00 PM
To quote the OP.........
"Then taking the part with the buttons on it you will see a spot to use the flat head to start to work your way around to make that come apart into 2 pieces."
Old Oct 19, 2014 | 03:42 PM
Staatsof's Avatar
Originally Posted by JagV8
I did mine before this write-up and it was so obvious that I had no problems.
I'm not even sure I followed the handbook other than maybe a quick glance.
Separating the transponder from the actual physical key is obvious.
The second part is not. At least not on mine.
Do I have to repeat the question?
Which way? Slide the two halves apart like the first break down or does one piece pop off the other?
Mine does not appear to move in either direction but the plastic distorts quite a lot when trying ...
It seems like it's going to break so if I'm going to break the gd thing getting it apart I'd at least like to be trying to separate the two halves in the right direction.
The OP and the owners manual neglect to mention that.
Old Oct 19, 2014 | 09:42 PM
Old Oct 20, 2014 | 06:32 AM
Staatsof's Avatar
That is EXACTLY the piece of information is was look for.
So the two halves get pried apart.
Thanks very much.
I think this tutorial should be in the database. It's more complete.
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
