Limited Slip Differential
Referencing this thread:
https://www.jaguarforums.com/forum/s...t=differential I tracked down the guy that did that swap and talked to him on the phone. He said the first gen lincoln ls's (<03) had a differential carrier that was DIRECTLY compatible with other fords, such as mustangs. The carrier in the second gens (<=03) is not, so you would need to put a carrier from a first gen (or thunderbird) on it in addition to a new differential. Getting a differential is very inexpensive (a couple hundred bucks at most for a ford traction-loc) and extremely easy, however neither he nor I would be sure about swapping the carrier. Some lincoln LS guys have done carrier swaps to put in an LSD so I'm guessing it is entirely doable for us. I'm curious if anyone here has gotten an LSD in their s-type, or what they think of this in general. |
when you say carrier do you mean case?
No, the carrier and case are different parts. The carrier is inside of the case and is where the axles are inserted and is where the internal clutches/springs of the posi/lsd are contained. The case is the thing you can see when your underneath the car and is what the whole differential and ring gear is inside of.
Greywolf, did you guys talk about the possibility of using a cobra carrier with its stock trac loc? |
OHHHHHH wait do you mean are the differential case and the carrier the same?? in that case, that would be a yes. I was just think about it and I remembered that is another term people use.
I find that these terms are applied pretty loosely :-)
In some circles the "case" is what the ring gear bolts to while the part you see under the car....the part that has all the guts inside....is called a "differential housing." <shrug> Cheers DD |
Originally Posted by greywolf40
(Post 117398)
If this, linky ,is a differential carrier; what is a differential? |
The carrier carries the gears and LSD clutches. The differential is the entire completed assembly carrier, gears, clutches and all. People just throw these terms around like Doug said. What we're looking for is the actual LSD differential, but there are certain things that make them fit in some cars and not in others. The number of splines on the axles is one of these technicalities, as is the number of bolts the holds the ring gear on to the diff. Lol all of these terms make talking about this extremely confusing. I looked for some decent diagrams on the web, but interestingly enough they don't really have any..
Originally Posted by whiteSTR
(Post 117550)
Greywolf, did you guys talk about the possibility of using a cobra carrier with its stock trac loc? http://www.kbxperformance.com/ Figured I would give him a plug since he was so helpful. He didn't say much about swapping the carrier, just that the carrier on the newer lincoln ls's (and I assume STR's) is incompatible and suggested swapping in a carrier from an older lincoln ls/tbird. I saw a couple newer lincoln LS's on cardomain.com that said they put a t-bird carrier and LSD in. I think all this is pretty legit, I was just hoping someone had already done it or might be willing to be the ginnea pig ;). A normal ford 28 spline traction-loc LSD will definitely fit the carrier, it's just a question of the carrier fitting the car. One final thing, I was told to find a tag on the differential, an extra metal tag normally threaded through a bolt on the case that ford puts on their differentials. It has all sorts of information like ratio, spline, open/limited slip, etc and would tell us for sure if this would work, but I was unable to find it on my car. Anyone else see a tag on the differential case for their S-type or STR? |
Haha yeah I do this on old Ford 9s and Danas all of the time when i find them in junk yards. For some reason mine has no tag as well. It must be a jag thing. Idk if it could be stamped on the axle somewhere or if Jaguar removes the tags before they put the axle in the car, but ours don't have them. (shrug) who knows.. Eric
(Post 117847)
very strange
ok so moving forward, If I order a Ford racing traction-loc diff (case whatever you call it) and a used LS differential (full loaded housing with ring gear) what else would I need to complete a the install of an LSD into my 03 STR? do I even need the LS diff?
From my understanding that should be all you need. You do not need the differential from the LS, just the carrier. However, it needs to be a first gen LS (<03), later gens cannot house the traction-loc dif. No guarantees of course, this is merely what my research indicates.
Anyone ever try any of this stuff I mentioned? I'm still holding out hope for an LSD in my STR :)
There are some things that we are still guessing at. Yes on the early Lincoln LS 2000-2002 model years you can install a Ford 8.0 LSD. However the ring gear and pinion will not swap. So the LS guys are stuck with just the factory ratios. In 2003-2006 The LS changed the read diff. Now on these cars you can go two ways. Adapt the earlier version set up which requires changing axles and drive shaft to the gen I LS stuff along with the diff itself. You can also do a complete custom install of a Lincoln MKVIII rear diff. This can also be done on the Gen I LS too. In fact several people have done this to get lower gears and it really makes a difference on the LS. This requires many more parts and is more expensive.
No one that I know of has verified how the Jaguar differentials all fit into this. I think the early Jaguar 1999-2002 cars share the Lincoln LS rear end and can install the same LSD. BUT Jaguar also changed or upgraded the rear diff on 2003 and up S Types. Until someone can physically compare a late model Jaguar to the Ford parts we just don't know what will work?? I have both a 2003 LS and a 2005 STR. Just looking at them side by side in the driveway they look VERY close if not identical. But my eyes are not that precise!!! Still hoping it will fit!!! . . . |
I am also hoping this can be done. I still have not finished some of my stage 1 upgrades my stage 2 is the rear diff. Hopefully this will be solved before I get to stage 2 if not I will have to try it myself.
Sorry! It was suppose to be 8.8 and NOT 8.0!
So Im rockin an 01 S Type which mustang years or whatever would i look for to get an lsd that would bolt 9into mine?
Here is a link to Quaife they have a LSD that will fit your car. This is for an XKR. You should contact them.
Search: Cars, Jaguar, XKR, Differentials - Quaife Engineering |
He has a Gen 1 S-type. IIRC, any LSD for a 99 & up Mustang 8.8 SHOULD work. I don't think anybody on this forum has tried this swap yet, but the Lincoln LS guys (who share the same underpinnings), do this swap alot. There is more info in the other LSD thread, too.
