Looking for better headlight bulbs for my '02
Greetings All,
Any thoughts on headlight bulbs for an early model S-Type? The low-beams in my car are only so-so. They just don't put out much light. I'd like to replace them with something brighter. All of the lenses are slightly clouded but I don't think that is a huge factor as the high-beams are stunningly bright. I can't remember what bulbs are installed in the low-beams, possibly GE Nighthawks. Per Rockauto, Hella H7 is a common number for these bulbs. They look like this, with an all-metal base: https://cimg4.ibsrv.net/gimg/www.jag...b7b1709eee.jpg Any recommendations? I'd like something that fits the stock sockets. If some aftermarket latest/greatest thing, I want something that doesn't trigger a bulb failure message. Thanks for any help. |
What brightness and color are you looking for...i bought some 8000k blues for my high beams off ebay for 23 dollars delivered....what a difference....i have hid low beams and bought 6000k for those and can see again....2 years old and still going strong...will edit after i get the sellers name...formula-J87 is the name...has a ton of selection...he is in Roseville CA....i used mequiars scratch and swirl for paint on my lenses and it made a huge difference...better than the headlight restore kits and cheaper |
Originally Posted by scottjh9
(Post 2039747)
What brightness and color are you looking for... Color? I'd like to stick to some variation of white. I'm not interested in the blue stuff you often see with the low-rider crowd. I'm an overweight middle-aged white guy who favors cardigans, not some young guy who for reasons unknown like to wear his ball cap sideways. |
I somewhat vaguely recall (OSram?) nightbreakers being mentioned.
Originally Posted by kr98664
(Post 2039752)
I don't know what brightness level I want, just better than I have now.
(Post 2039752)
some young guy
Originally Posted by joycesjag
(Post 2039961)
Karl I think you may be mistaken. Sum Yung Guy owns our local Asian flair restaurant. His crab ragoons are to die for!
(Post 2039995)
Good one
Good one* (*if you're into cheap, low-brow humor) Meanwhile, I only use the finest of jokes, flown in fresh from around the world. For example: What's green and wears ice skates? |
(Post 2039996)
(Post 2040106)
Dorthy Hamilll in a frog costume*
Peggy Phlegm |
https://cimg1.ibsrv.net/gimg/www.jag...c58953e30.jpeg
(Post 2040119)
Peggy Phlegm Oh hoo hooo Oh hoo hooo, that there is a knee slapper Oh hoo hooo* |
(Post 2040125)
(Post 2039752)
I would try one of these:
OSRAM NIGHT BREAKER LASER H7 64210NL-HCB: Philips X-treme Vision +130% H7 12972XV+S2: Just a straight swap and they produce a much more focused light than standard bulbs. Life might be a bit less because to focus the light better, the filament is usually smaller. I swap them every couple of years as they are fairly cheap. |
Originally Posted by neilr
(Post 2040190)
Philips X-treme Vision +130% H7 12972XV+S2: |
(Post 2040199)
Thanks, I ordered the Philips
Safari, so goodie!* The Philips bulbs are definitely brighter, and the hue seems the same as previous. Definitely not the blueish high school drug dealer look, so that's good. I also wondered if my lights were aimed down too low, so I turned each adjuster in one full turn. That seems to have helped, too. This weekend I plan to play with the adjusters a little more after dark. |
