Manual handbrake brake cable
Old Mar 30, 2020 | 07:54 AM
Earsjohnny's Avatar
Default Manual handbrake brake cable
Hi as anyone got any pics on where the rear handbrake cable fits on back end of s type before the calipers I have two brackets but can't find where they fit thanks it's 1999 plate
Old Mar 30, 2020 | 05:27 PM
NBCat's Avatar
@Earsjohnny, here is a link to the X200 Workshop Manual:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
Refer to section 206-05, page 498 of the PDF.
Old Mar 31, 2020 | 06:01 PM
Paul792's Avatar
Default Photos of the brake cable bracket
These two pictures are from an early X200, 1999 model. I took them, so there not that great. But should give you an idea.
The cable runs through a bracket seen from the back of the spring in this photo. The bracket is bolted to the subframe with a 10m bolt. Look for a threaded bolt hole that is behind the top of the spring on the subframe. That is, when you look at the assembly from the disc rotor in the direction of the spring. Normally, it has a bracket that is bolted on the frame and bends around and sits at the bottom of the frame. If you find the bolt hole then the brackets you have will bolt to this. There is a smaller hole down from this that the brackets will align with and should then fit into flush to the subframe. I hope this can make sense to you when looking at the photos.
Looking from the rotor inward
Closer view
XJ8JR
Jul 31, 2017 02:12 PM
Jaguar brg
May 31, 2016 02:03 PM
daboss085
Sep 12, 2012 07:08 PM
dustedu5
Mar 13, 2009 09:23 PM
