misfire problem 4.0 V8
its a v8 4.0 S-Type.
ok, little history, I used to have a misfire on number 3 and 8, that was fixed by changing all the spark-pluggs and changing 2 coils. now I have a misfire on 2 and it happens when your going between 45 mph and 55. when its idling its fine or above 55 its fine, its always after 45mph :icon_werd: what do you think? :icon_denk: thanks for your help |
sounds like more coil pack issues, when one goes they all start to go i had the same issue. Also when i was having missfire issues i changed my mass air flow sensor. But check all your coil packs first
Good advice.
Jaguar struggled with S-Type coil suppliers in the early years (1999-2002). Several different designs were tried, and the coils were somewhat better in the 2003-2004 models. By the 2005 models, the coils were apparently up to average industry standards. Still not great, but at least better than a poke in the eye with a sharp stick....
Lincoln LS uses the same coil.
Thank you so much everyone, that helps a lot.
Thank you again |
